1991 Accord Coupe Drivers Window Help Needed
Hello
I own a 91 Accord Coupe and the clip that holds the window has broken off and I would like to request assistance in repairing it. I also do not know what the part is called so I would need to know that as well.
Thank you
Thank you
Have you tried searching the owner's manual for the name of the clip it? Is it metal or plastic? If you don't have a manual you could look at manualsonline.com they have downloadable ones. What you would be looking for is like retaining clip or retainer or something along those lines as for the name of that particular clip. Then you can probably You tube a video if no one here is able to help on how to replace the particular clip. Pay attention to the size or part number of the clip when you find out which one you need.
Thank you. The clip holds the oversized glass of the coupe which in turn is set into a guide to keep the window stable and to close properly. I will check out the manualsonline site to see what this is called and also to get the part number.
Again thank you!
Again thank you!
Go to one of the many online Honda dealer web sites and look up the parts/pieces you are looking for?
One example: http://www.hondaautomotiveparts.com/...ry5=DOOR+GLASS
trublu006
Sep 12, 2017 07:04 PM
dwalls32
Jun 18, 2007 04:54 PM
