98 Civic won't start - engine doesn't crank
Old Aug 31, 2013 | 06:38 PM
BigDuy01's Avatar
Default 98 Civic won't start - engine doesn't crank
First off, i want to say thanks to all of you for helping me.
One minute my civic is running fine and I turned off to get gas and I cannot restart it. All the lights work and function. I'm able to turn my key and the first and second position works fine. The third position would not start my car. It does nothing. I was able to push and pop the clutch to start my car.
  • Battery is good
  • Starter is good
  • Clutch safety switch works. I bypassed it by tying the two wire together.
  • check all the fuses and they look good. I didn't know how to check the box fuse.
I'm at a big lost. Please help.
Thanks,
Duy
Old Aug 31, 2013 | 07:03 PM
trololog's Avatar
Default Re: 98 Civic won't start - engine doesn't crank
Hi, I had a similar issue with my EH9 3 months ago, it was the solenoid. Only for test purposes the mechanic at that moment hit easily with a little hammer that part while trying to crank an then the engine started. Then he had to repair it, I think there are some filaments that get dirty with the usage and need to be polished.
Also I think you should check your sparks plugs, cables and at the end the fuel pump.
Hope, this helps a little.
Old Sep 1, 2013 | 05:24 PM
teamXteg's Avatar
have you done any testing on the ignition switch its self?
Old Sep 1, 2013 | 07:32 PM
BigDuy01's Avatar
Thank Trololog. I will look for the cable at the end of the fuel pump. I need find out where it is. I have replace the starter on it and it doesn't work so I don't think it's the starter solenoid.
Thanks teamXteg. I have not done an ignition switch test. Can you tell me how to do that?
Thank you to you both for helping.
Old Sep 1, 2013 | 07:34 PM
eghatch9295's Avatar
Stancetard Hate Monger
pull the plastic switch off the backside of the ignition assembly. look for burn marks, etc. id start there.
Old Jul 8, 2022 | 09:25 PM
catina's Avatar
Old Jul 8, 2022 | 09:26 PM
catina's Avatar
We are having the identical problem. What was the issue?
JorgeR559
Jun 10, 2014 10:50 AM
ReSpade
10
Mar 3, 2014 08:27 AM
dherna9846
May 8, 2013 05:56 PM
NoLimitCivic
May 9, 2012 09:00 AM
94turbo
11
Jul 3, 2009 05:02 AM
