Will 96 instrument cluster work in a 94
Old Aug 31, 2013 | 03:27 PM
76 camaro car's Avatar
Default Will 96 instrument cluster work in a 94
I know that it looks the same but I am concerned that the wiring harness plugs may be different. Does anyone know if they are the same? My gas gauge has not worked in 10 years and the odometer is getting stuck when I reset the maintenance reminder. I found one out of a 96 and want to be sure it will work before I spend $30. on it.
Old Sep 1, 2013 | 08:16 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Will 96 instrument cluster work in a 94
As a complete cluster it will bolt in no problem.
The major differences is if you put a coupe cluster into a sedan/wagon it does not have the warning lights for the back doors.
But if you have an early '94 and are trying to gauges around there is a difference in Tach circuit boards.
Old Sep 1, 2013 | 02:16 PM
Cool, The 96 I'm getting it out of is a 4 dr. sedan and my car is a 94 4dr. sedan. I am switching the whole cluster so I guess it will work. Thanks.
76 camaro car
Aug 31, 2013 07:22 PM
jdmsteveo05
Dec 31, 2006 01:04 PM
preludevtec96
Apr 29, 2005 08:32 AM
