Will 96 instrument cluster work in a 94
Old Aug 31, 2013 | 03:00 PM
76 camaro car's Avatar
Default Will 96 instrument cluster work in a 94
I know that it looks the same but I am concerned that the wiring harness plugs may be different. Does anyone know if they are the same? My gas gauge has not worked in 10 years and the odometer is getting stuck when I reset the maintenance reminder. I found one out of a 96 and want to be sure it will work before I spend $30. on it.
Old Aug 31, 2013 | 03:13 PM
NZXTInerTia's Avatar
Default Re: Will 96 instrument cluster work in a 94
Just buy one out of a 94?
It should work if the three digit code works. There is either a 168 or a 167 cluster, you need whatever one your car has.
Old Aug 31, 2013 | 03:18 PM
CokeZero's Avatar
A quick search online revealed clusters from 94-97 are the same when trying to buy one. That means the plugs will be the same on the rear. If there was a difference in plugs they wouldn't sell by a year gap like that. It would be something like 94-95 accord cluster. Then 96-??? accord cluster.
Old Aug 31, 2013 | 03:31 PM
The u pull it only has a 96 that still has the cluster in it.
Old Aug 31, 2013 | 04:39 PM
Ah, gotcha. Just make sure its the same 186 or 187 that your existing cluster has. This is a thread I wrote up about a damaged tachometer that I had to replace in my 94.
https://honda-tech.com/forums/honda-accord-1990-2002-2/accords-94-95-gauge-cluster-tech-3159887/
Old Aug 31, 2013 | 05:12 PM
https://honda-tech.com/forums/showthread.php?t=3159887
Just read your thread. Is the tach face mounting screws difference noticeable enough to tell difference by just looking at the two?
Old Aug 31, 2013 | 07:22 PM
I found that it was, but I also had them directly in front of my face too. Considering you have to pull your cluster ANYWAYS to replace it, I would just verify what number/model it has and then reference it to the new one you're looking to replace it with.
76 camaro car
Sep 1, 2013 02:16 PM
Dan GSR
Sep 17, 2002 07:51 PM
