Ideal afr for stock b18b1
Old Aug 31, 2013 | 05:12 AM
BIGef's Avatar
Default Ideal afr for stock b18b1
As title states its a stock b18b1 with I/H/E
89 civic sedan obd1 p75
My afr for idle is at 14.6-14.7
What would be best for WoT? Looking for more hp.
Sorry no dyno in our area looking for opinions
So we just street tune
Thanks in advance
Old Aug 31, 2013 | 05:58 AM
DDTECH's Avatar
Default Re: Ideal afr for stock b18b1
For something like this 13.5-13.3 would probably be around ideal. Some cars like it richer like 12.9, others like it leaner in the 13's.. really depends
12.9-13.5 is a fine targert to shoot for.
Old Aug 31, 2013 | 04:22 PM
BIGef's Avatar
Thanks for the reply ddtech! What I needed
Old Aug 31, 2013 | 06:22 PM
blackeg's Avatar
i used to run a stock ls at 13.5-13.7 wot with stock timing and 93 octane. it never had any issues and ran for tens of thousands of miles through multiple owners. honestly tho id shoot for a little richer, right around 13.3
Old Sep 2, 2013 | 11:40 AM
FlewByU352's Avatar
12.8:1 - 13.2:1 is usually the sweet spot in power and reliability for an all motor setup at WOT. You can gain throttle response and pick up some power leaning out more in 1st and 2nd gear usually up to 13.5:1.
Idle at full temperature 14.7:1 is stoichiometric. 5th gear cruising with minimal load can be leaned out to even 15.5:1 but anything leaner than 14.7:1 produces a large amount of NOx and sometimes with minimal MPG increases. Shoot for 14.5:1 cruising and it will be fine.
Old Sep 2, 2013 | 10:17 PM
BIGef's Avatar
thanks for the reply. We got only 91 octane in our area.so probably go with the richer side? and maybe 18 degree ignition timing
ill just keep testing and tuning at those afr to see which makes power more.
I hit 15.4 at the track want to see if I can get to 15.0-15.2 with just fine tuning.
In our area since its just a small island. our max mph is 45 so I cruise in 5th gear right around 2k rpm. Shifting a 2k-2500 rpm. so 14.5:1 is what I should be aiming for?
jdm 1080p
Apr 4, 2012 01:57 PM
Dasfinc
Jun 25, 2008 10:17 AM
da9blacksheep
Mar 23, 2005 07:57 PM
wolfsburg2
Mar 26, 2004 07:29 AM
