Crank but no Start b16a
Old Aug 30, 2013 | 09:07 PM
CKnight90's Avatar
Default Crank but no Start b16a
So here's what I know whats wrong with it before it died and didn't start.
code 10 (ait)
Throwout bearing
My car/engine(b16a NA Bone stock/99 Integra GSR) was running strong with no issues(besides what I listed up top). I changed the oil and the filter. Went to the gas station. VTec hit hard. Got gas. Pulled out the gas station. Get in 2nd gear. Then it stuttered, and died. I tried to start it about 10 times. My bro showed up. We pulled into an empty lot. Pushed it and tried to pop clutch to start, which wouldn't run/start. Reset ECU. Checked ECU and ecu fuse. Checked all wires and made sure they're plugged in. In the past I've replaced the igniter. Other then that no trouble with any other parts. Starting it so many times I could smell gas, also the fuel guage under the hood was staying at a constant pressure.
I'm stumped and I'm not to good with figuring out things. I want to learn though!
Please help! My daily driver!
Old Aug 30, 2013 | 09:13 PM
DDTECH's Avatar
Default Re: Crank but no Start b16a
Main relay clicks? Do you "hear" the fuel pump prime up?
Ensure you are getting a good fuel supply. Then check spark. Report back.
Old Aug 31, 2013 | 06:15 AM
Eg.ls.turbo's Avatar
Mayb jumped timing? Check timing
Old Aug 31, 2013 | 06:53 PM
CKnight90's Avatar
So My uncle tow roped me back. As he was pulling I tried to pop the clutch(30mph). Engine just rotated but no spark. So when I got home I took out the Igniter I replaced over a month ago. Put my old one in. Car started right up. I noticed my old igniter had black spot on it. Brought it back to parts store. Got an upgraded lifetime warranty one, and better brand. Installing tomorrow!
FIXED!
ALSO need help with this and other sites wont respond!
Is this one blink code 10 or 1? https://plus.google.com/111753519241...ts/VBgKuKckH4i
Since my car is obd2b/obd2 converted does it matter what code key I use?
95/99 Conversion(obd2b/obd2) Integra GSR - B16a - 5 speed
Old Sep 3, 2013 | 05:38 PM
CKnight90's Avatar
bump
Anyone?
Old Sep 9, 2013 | 06:22 PM
CKnight90's Avatar
bump
onelostcoupe
Mar 23, 2017 08:32 PM
Pnutty209
Dec 28, 2012 11:01 AM
still4punk
Apr 26, 2011 03:00 PM
dan89crxsi
16
Sep 24, 2006 01:22 PM
garagespecial
Jun 25, 2002 10:00 AM
