Base 270 injectors in Type S?
Long story short, got a motor that had been sitting. The injectors were locked up solid. Applied 12 to them to try and get them clicking and opening up but nothing. Ended up buying a set locally which ended up being base 270's. Are these usable in my setup? Basically a stock k20a2 with Kpro. Or will these not flow enough?
they will be fine at least temporarily. not sure if they will handle the high rpm flow needed at 8000.. but they will work as long as u set them right in kpro and tune it
i would get the 310cc, so you get the most out of your cars power, but if you are not maxing them out for whatever reason with only using 280cc, then i would keep them. I have 310cc with rbc, header, cai, kpro, and its close to max
