Parting car: Garrett/ Hondata /comp clutch/ manley/ supertech/ magnafuel/ and more
Old Aug 29, 2013 | 07:28 PM
paulzy's Avatar
Default Parting car: Garrett/ Hondata /comp clutch/ manley/ supertech/ magnafuel/ and more
Parting my build because I'm moving on with my life, currently have more important things going on right now than racing. Everything is new unless noted. Posting as many pictures as I have but if you need more, just let me know. Not everything is pictured. I have many vouches if you need them.
Ferrea stainless steel valves for B-series (STD size, used for a few thousand miles) $125
Golden Eagle thermal intake gasket for b16/ITR- $20
AEM 5bar Map Sensor (new)- $120
98 civic stock tank with sump / -10AN bung (new)- $140
B-series starter out of GSR (reman'd napa)- $50
Golden eagle LS/vtec Kit- $80
B-series valve cover with -16AN bungs welded for catch can (painted wrink black and shaved, new gaskets, AN caps for bungs included)- $100
Edelbrock victor X 75mm throttle body with vanjen setup welded to inlet w/ adapter for Honda bolt pattern(TB is used, adapter plate and vanjen setup new)- $240
OBD1 tuck harness built by thevtecnician- $300
MFactory LSD for GSR with brand new with new bearings- $650
Magnafuel Prostar Fuel pump (used, part #MP-4701)-$450
comes with -10AN inlet and outlet fittings
Precision 6266 / journal bearing / 1.32a/r divided T4 housing / Ported Shroud "S" cover (new in box)- $900
GSR OEM shift linkages- $80
S&W racecars parachute mount and anchor kit, cable, and lever kit (brand new)- $75
S&W racecars window net, blue (brand new)- $20
K20a2 OEM camshafts (no gears or pulse plates)- $80
PRB intake manifold- $40
Stock GSR gearset- $160
Old Aug 29, 2013 | 08:10 PM
hetap's Avatar
Default Re: Parting car: Garrett/ Hondata /comp clutch/ manley/ supertech/ magnafuel/ and mor
s300 come with boost by gear?
Old Aug 29, 2013 | 08:22 PM
paulzy's Avatar
yes but no solenoid.
Old Aug 29, 2013 | 09:58 PM
lightspeed_DA's Avatar
Text me 14084398066 interested in pro1 cams and bloc drag coil
Old Aug 30, 2013 | 12:09 AM
GsrinLS's Avatar
Interested in the Fuel rail and tuck harness, hit me up with a Pm!
Old Aug 30, 2013 | 02:32 AM
Shaun Inlow's Avatar
would you take $400 for the s300, if you email me at sinlow1980@gmail.com and I'll pay for it
Old Aug 30, 2013 | 03:43 AM
dcmatt's Avatar
Bunch of nice goodies. Be trying to grab some stuff up here soon.
Old Aug 30, 2013 | 06:17 AM
Highboostedsol's Avatar
will you sell the wheels with out tires
Old Aug 30, 2013 | 06:28 AM
Bump.
Old Aug 30, 2013 | 09:36 AM
paulzy's Avatar
will text you in a bit but the blox are sold
pm'd
sorry but I'll pass
thanks
yes. $1600 without the tires
Old Aug 30, 2013 | 11:04 AM
paulzy's Avatar
added more pics
Old Aug 30, 2013 | 12:22 PM
ballistic1350's Avatar
s300 sold to me!
Old Aug 30, 2013 | 03:58 PM
paulzy's Avatar
Originally Posted by ballistic1350
s300 sold to me!
PM'd you the tracking number earlier
Old Aug 30, 2013 | 08:20 PM
dcmatt's Avatar
Ill take the headstuds. Pm or txt me 7042583216
Old Aug 31, 2013 | 01:28 PM
Interested in the cams text me
Old Aug 31, 2013 | 01:55 PM
paulzy's Avatar
texted both of you guys.
Old Sep 5, 2013 | 12:53 PM
nick1048's Avatar
Interested in both tial 38mm MV-S
is it BNIB and everything in the box?
send me some picture
If I take both can you give me a better deal?
480-734-7244
Old Sep 5, 2013 | 01:44 PM
paulzy's Avatar
updated the list
Old Sep 5, 2013 | 07:20 PM
Matthewhughes's Avatar
What's all included in the ls- v kit? What's new, what's used?
Old Sep 6, 2013 | 09:29 AM
paulzy's Avatar
Everything besides the head gasket and the little 1/8pipe plug which u can get cheap at the hardware store. The only thing that is used is they ate itself. All the lines and fittings are new Daryl's black anotuff fitting and braided nylon line
Old Sep 6, 2013 | 10:04 AM
mastrhuntr's Avatar
does the ls/v kit include head studs?
Old Sep 9, 2013 | 09:23 AM
paulzy's Avatar
no. they usually don't
Old Sep 12, 2013 | 07:04 PM
paulzy's Avatar
bump. need this stuff gone guys.
Old Sep 13, 2013 | 07:39 AM
EJ1_Ex's Avatar
bump
Old Sep 17, 2013 | 11:34 AM
paulzy's Avatar
bump
