96 Honda Accord LX with oil around spark plugs wires
Old Aug 29, 2013 | 05:07 AM
Wingnut83's Avatar
Default 96 Honda Accord LX with oil around spark plugs wires
Hi I need help with a problem. My wife's 96 Honda Accord LX has oil leaking around the spark plug. We have replaced all the valve cover gaskets. Including the 4 o rings under the rocker arm. My question is why would it still be leaking? My brother in law asked a honda mechanic and he thought most likely thought that something might be warped. Any ways looking for some ideas as to what might be wrong before I go into the mechanic, any help would be great.
Old Aug 29, 2013 | 05:10 AM
Wingnut83's Avatar
Default Re: 96 Honda Accord LX with oil around spark plugs wires
Forgot to say it has almost 146,000 miles.
Old Aug 30, 2013 | 12:41 AM
holmesnmanny's Avatar
you replaced all 8 orings (4 under rocker arm and 4 at the top of the spark plug tubes) ?
Old Nov 23, 2013 | 04:46 AM
triet43's Avatar
I have the same problem with my 94 Accord LX, 275K. I've heard there's gaskets under the cam shaft that can cause the same problem, if you've replaced the ones above already. But I'm a noob, so would love to know if you get it solved, since I'm in the same boat.
Old Nov 23, 2013 | 10:12 AM
cranecar's Avatar
I have the same problem. Found it last night while changing the plugs, lines, distrib cap.
Packie12321
Oct 23, 2013 11:30 AM
jthrasher1
Jun 28, 2009 10:19 AM
aka_bigred
Oct 30, 2007 10:45 AM
gian13
Mar 28, 2007 07:11 AM
tony n.
Oct 26, 2005 10:58 AM
