Wheel specification help?
Old Aug 28, 2013 | 06:16 PM
Low and no vtec's Avatar
Default Wheel specification help?
Hello!
Trying to figure out a decent 'stance' on an ej Sedan?
Pretty much, daily driven, and I don't want to have to flare the fenders, a mild roll/pull is fine.
Or are flaring fenders almost a requirement?
I heard 16's are a bad idea, but I come from integras where 16x8 +15 is what I rode.
I saw some guy with 15x8 +15 or something today, and he was super low, but his camber was insane..
15x7's here I guess? With what offset to achieve something like this?:
Or this?
I understand that it'll wear tires, yada-yada.
I daily it, a pretty long distance too and from work, and will have toe set perfect, but will have NATURAL camber. Will NOT be getting a camber kit.
Pretty much trying to figure out the specs on those wheels^, or if anyone has any comments or pictures about 16x8 +20 or 25?
Tire size will be 205/40/16, as that is what I have been using!
Thanks a ton!!
Old Aug 28, 2013 | 06:33 PM
Default Re: Wheel specification help?
Or even 16x7 +20 or so, if the 8's run too much negative camber for a daily driver...
Can't find any legit pictures..
Old Aug 28, 2013 | 09:55 PM
elly7b's Avatar
16x7 or 16x8 with around a +25 offset would be fine, with 195's or 205's. won't need a camber kit if you lower it enough to where natural camber takes place.
If you go 8's though, any tire shop will recommend a 205 at least.
Old Aug 29, 2013 | 03:32 AM
jdmh22eg2's Avatar
if you want a PROPER non stanced ****. in 15's then 15x7 +35 is about all you should run with out really pulling the hell out of your fenders. that setup on a eg needs 1.4* of front camber not to run on a lower set up with 205-50-15 tires. 16's are ok on an ej as well but need to run a little less more offset in the +40 range
Old Aug 29, 2013 | 07:55 AM
What do you think the specs are in the pictures? Any clue? Thanks for the help, as well.
And Iwas told with 16x8 et20.i will need spacers and extended studs?
does anyone have pictures of 16x7 et40 on a lowered ej? Rota grids, lol..
Old Aug 29, 2013 | 07:12 PM
toyomatt84's Avatar
Sanji
Both of those examples are near the 15/6x7 +35 range, just for your information.
Also...
From the Forum Rules and FAQ:
6b. No opinion threads for the appearance of wheels.
Examples:
"Which wheel will look better on my car?"
"What color wheels should I get?"
JsSIR
May 10, 2014 04:07 AM
Low and no vtec
Aug 28, 2013 09:40 PM
evosix
May 25, 2009 12:30 PM
jkn1515
Honda S2000
19
May 27, 2007 06:19 AM
ruiner17
Apr 3, 2002 11:00 PM
