K20 Eg= Time Attack Beast
So here it is, ever since i got my 06 habi si i have wanted to get a hatch to do a k20 swap in it. Well it finally happened, i picked up my 94 Honda Civic CX back in February of 2011 with half and engine, for 500 bucks. I think its a damn good price.
I am building this car for time attack events and strictly cornering/race purposes only. I am going to be doing everything myself so this should be very fun and i have a good shop to do it in. I hope all you enjoy watching the progress as much as i love love building it!! I will be putting a k20z1 motor in with the stock 6 speed tranny, well i hope you enjoy!!!
New Pictures near bottom!!
Engine Mods:
-RBC Intake Manifold-Courtesy of K20z3allmotorftw
-Hondata Intake Manifold gasket-www.hybrid-racing.com
-Hybrid Racing Throttle Body to intake manifold Adapter 64mm-www.hybrid-racing.com
-Custom painted valve cover-by ME
-Karcepts A/C & Power Steering Delete kit-www.hybrid-racing.com
-PLM 4-2-1 Header www.Hybrid-racing.com
-Hasport Engine Mounts-Hmotorsonline
-Stock 02-03 rsx tpye-s engine harness-www.Hybrid-racing.com
-Hybrid-racing Fuel Rail-www.Hybrid-racing.com
Interior Mods: So Far
-Full 6 point roll cage welded in not bolted in.
-Red Sparco Seats
-Sheet Aluminum Door Panels
-MOMO Steering Wheel
Extirior Mods: So Far
-New Front Bumper-Parts Channel
-New Front Fenders-Parts Channel
-New Front Corner Lights-Parts Channel
Suspension/ Brakes/ Wheels & Tires:
-Skunk2 Upper Control Arms with Adj, ball jonts-Corsportusa
-Ksport Rear Lower Control Arms-Corsportusa
-Stock New civic ex lower control arms-Autozone
-Rear Disc Brake Conversion from a Del Sol-Hondamotorsonline (A.K.A- Hmotors)
-Energy Supsension Rear Trailing arm Bushings-Corsportusa
-ARP Extended wheel studs-Ebay
-Wilwood Big Brake kit- www.Wilwood.com
-BWR Black Lug Nuts-EBAY
-Password JDM Rear drilled/slotted Rotors-Password JDM
-Hawk HP PLus Brake pads-Password JDM
-BLOX Rear Adjustable Camber Arms-Corsportusa
Finally got my K20z1!!!!!
Starting to take out the old motor.
Pulling the motor out :-)
Old 1.5L peice
Priming the engine bay to get it ready for paint!
Xmas Presents!!!!
Skunk2 front upper control arms with adj ball joints
Ksport Rear lower control arms
Undercoating the fender-walls. and painted the upper control arm mounts, and started painting the engine bay!
fully painted engine bay! Also installed new Civic Ex lower control arms and Skunk2 uppers.
Painted the valve cover :-)
Full Roll cage just got put in!!!
Painting the inside white and rollcage white!!
Pilar Gussets!
Karcepts A/C power steering delete kit
RBC intake Manifold customized and fitted nicely, with hondata mani gasket, and with a mild port job.
Courtsey of Parts Channel, I got my front bumper and both front fenders and both corner lights.
Fully Painted engine bay with motor mounts installed.
Done painting interior and cage. Interior is all white except for where your feet go that painted black.
Throttle body install with Hybrid-Racing Throttle body Adapter.
Put in my rear disc conversion from a del sol with energy suspension trailing arm bushings, and put on my k-sport rear lower control arms, Annnddd i got Arp extended wheel stud put in as well.
Got PLM Header installed.
Fuel Rail installed.
Got my big brake kit installed 11" rotors 4-piston calipers
Engine is in!!!!
Rear Brake rotor's and brake pads installed.
Engine Mods:
-Red Sparco Seats
Old 1.5L peice
Xmas Presents!!!!
Pilar Gussets!
Engine is in!!!!
If you loved me, you'd all sell me your magic cards to me today
thanks everybody for the positive comments, it def helps me out knowing i'm doing a good job and people enjoy it, since its my first swap/build. The finish colors will be Car- white Wheels-Black engine bay-green with orange valve cover.
You're going to weld down the passenger side mount right ? what suspension set up are you going with what spring rates will you be running along with what RSB ?. just curious why didn't you go with spherical bearings for the FLCA/RLCA/RTA/UCA they make a huge difference if you have all of them I like mine that's why I'm asking. As for aero you going with a splitter/rear diffuser form P1 motor sports ?. defiantly has the potential to be a fast time attack car, where are you racing it ?.
I know getting all the bushing replaced would have made it feel better and all but all the flca and rlca are brand new with new bushing once those all wear out then i will get the whole kit and do every single one and im not sure what coilovers i am going with but most likely tein flex. No splitter or wings at first but jay's racing has a great wing that im looking at. And why would i weld the passenger mount down?
Damn i didnt know i was being interviewed haha.. but thanks for the curiosity!
Tein flex's are what I ran my first season, I liked them a little soft tho with 10/7K I switched this season with some MCS shocks and 20/16K springs w/32mm hollow bar. Why not weld it the OEM side mounts are welded just more secure, yah just interested as not many ppl do time attack oriented builds, more auto x etc. Came kinda close to making it to the global time attack SLB at buttonwillow last year awesome to watch if you live in the area tho. alot of neat stuff gets posted here https://honda-tech.com/forums/forumdisplay.php?f=19
PR8urVtec
Aug 3, 2015 04:07 PM
Snail Power
Sep 27, 2009 05:11 AM
