gsr butterfly removal...
Old Aug 27, 2013 | 07:09 PM
mkeacura's Avatar
Post gsr butterfly removal...
Ive been thinkin about buying a top shelf intake manifold but i thought about keeping the stock manifold and just removing the butterflies. Has anyone ever done this? I figure if I take the butterflies out, itll more or less be a ported itr manifold. Yes, No? Feedback?
Old Aug 27, 2013 | 08:18 PM
B_Swapped93's Avatar
Default Re: gsr butterfly removal...
No it won't it still has a really restrictive design what you can do is unhook the IAB connector plug or get a chipped ECU(non p72) so the butterflies will stay open all the time. my advice: get a Skunk2 intake manifold 70mm plenum opening so you can happily run a 70+mm TB. have them open is just as effective as if you were to remove them.
Old Aug 28, 2013 | 12:30 PM
frost_white_ej1's Avatar
keep in mind removing the butterflies or finding a way to bypass the iab to open all the time will suck for normal dd you will feel lag in the lower rpm.
Posted from Honda-tech.com App for Android
Old Aug 28, 2013 | 12:39 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
I think if you apply straight vacuum to the iab diaphram, they will constanly stay open.
Old Aug 28, 2013 | 12:43 PM
What ? no you don't I didn't notice **** when I got my chipped P30 and then once again when I swapped over to my skunk2 intake manifold. That WHOLE manifold is restrictive as hell open it up and look I did when I got my skunk one.
Old Aug 30, 2013 | 01:22 AM
you want to buy mine for $40 and see for yourself?
mine lag like crap it not bad but you do notice it when you do easy acceleration on normal dd.
Sloshy
10
Jul 29, 2006 07:48 AM
danteisme
Feb 26, 2004 04:28 PM
dingusjt
Apr 8, 2003 06:40 AM
four27
Dec 13, 2002 07:06 AM
