Best Race Header for the price ?
If you are planning a swap wait till you have the A2 in and then get a header... Skunk2 Alpha header has been a strong performer in terms of power out put!
AND I have the K24a2 swapped in and am running OBX V2 RH's and they hit the undercarriage. Will the K-Tuned ram header hit?
I have the K24a2 swapped in and am running OBX V2 RH's and they hit the undercarriage. Will the Skunk2 Alpha header hit?
on stock to mild modified engine Skunk2 header will give you best powerband, and quality header on the market
I did test on special build header by Hytech and ASP in the past for k20z3, and skunk2 did the exact same power, on the exact same engine, all those done the same day
All depending how much you want to spend, of douse brands like asp are pretty up there in price but you can find them used for a decent price. Not sure what brands exactly fit for your car though.
UPADTE:
After install of OBX V2 RH and K24 swap mid pipe was resting on the under carriage and making lots of noise. After looking at it on a lift there is 1 spot under the passenger seat where it hits. A little hitting and bending upwards on that small spot of the under carriage and it doesn't hit or make any more noise. They do open up the exhaust and add to the overall performance sound. So as of now I would have to say I'm very pleased with the OBX V2 headers. They are Comptech replicas and a good bang for the buck.
MainStreamHonda
Aug 9, 2011 09:36 AM
si0385.
Aug 24, 2006 04:48 AM
chrishede
Aug 10, 2004 09:31 PM
YEE*MagicEK20kombobomber
Feb 29, 2004 08:04 PM
