Help! Back to get reamed out again but I need the help..
Old Aug 27, 2013 | 11:40 AM
Dasnegro's Avatar
Default Help! Back to get reamed out again but I need the help..
Ok I'm back but with the motor up and running..
But does not idle.. I have checked all the sensors am fixed the codes
I can't find any vacuum leaks
Checked and rechecked timing at 16deg
The cat is new
Plugs and wires are new
New timing belt
New water pump
Seals from the head gasket up..
Jdm p30 ecu
There is a s300 going in in the next few weeks but still not 100% that will fix my problem
Old Aug 27, 2013 | 12:27 PM
Dasnegro's Avatar
Default Re: Help! Back to get reamed out again but I need the help..
sry I was trying to upload the video but it is to large
Old Aug 27, 2013 | 03:35 PM
motoxxxman's Avatar
try telling us what motor it is, and what mods you have done to the motor.
Old Aug 27, 2013 | 03:47 PM
EsotericImage's Avatar
Retired Moderator
tps and map mixed up?
Old Aug 27, 2013 | 03:53 PM
F22Master's Avatar
Did you check the idle air adjustment screw? It's the brass screw on the top-front of the throttle body. It should be somewhere around 1 turn out, but maybe more. Start with 2 turns out and lower from there. The more turns out, the higher the idle.
Old Sep 2, 2013 | 07:00 AM
Dasnegro's Avatar
mostly it has head work done
stage 2 street cams
.5mm oversized valves
new valve train, springs, retainers, seals
6 thou milled off head
new head gasket, intake gasket other assorted gaskets
new distributor, alternator
new belts, hoses, plugs, wires
cleaned IACV verified working with DVOM
timing at 16 degrees
computer reflashed p30ecu
have checked all sensors and connections, checked for vacuum leaks
idles between 300 an 500 rpm
no check engine light
the only other issue I seem to be having with the motor is it will not engage vtec ( I believe I am no getting enough oil to the solenoid, but this is a different issue)
Old Sep 2, 2013 | 08:05 AM
98vtec's Avatar
moderator emeritus
What is a stage 2 street cam?
Old Sep 2, 2013 | 08:45 AM
motoxxxman's Avatar
you still haven't told us what motor it is.
Old Sep 2, 2013 | 02:50 PM
bks84's Avatar
Loved
You're positive you did your mechanical timing correctly?
Old Sep 10, 2013 | 01:58 AM
Dasnegro's Avatar
Oh sry
It's a Jdm b16
And yes I have triple check the mechanical timming
Old Sep 10, 2013 | 02:01 AM
Dasnegro's Avatar
--street cams-- 1st and 2nd lobes are not much more aggressive then stock
Old Nov 21, 2013 | 11:37 PM
Dasnegro's Avatar
Its a 94 block and head
Old Nov 22, 2013 | 10:36 AM
motoxxxman's Avatar
did you adjust the idle screw like mentioned above?
do you have anything blocked off, like the brake booster, iacv, fiv, pcv, etc?
onlinmrine
Feb 10, 2022 12:17 PM
Spencedaddy12
Acura TSX
Mar 15, 2018 07:41 PM
gasketboy
Mar 6, 2017 11:16 AM
egtt21
Apr 14, 2013 04:01 PM
raider1qaz
Feb 1, 2013 12:44 PM
