ignition wires. which is which? (97 del sol si)
Old Aug 27, 2013 | 09:23 AM
mish__'s Avatar
Default ignition wires. which is which? (97 del sol si)
So on the interwebs I got...
12V CONSTANT WIRE WHITE
12V IGNITION WIRE BLACK/YELLOW
STARTER WIRE BLACK/WHITE
ACCESSORY WIRE YELLOW
but after blowing an ignition fuse and power doors/windows not working... I checked the side of the wires on the cylinder and it reads...
Acc =white/black
Batt = white
Ig1 = black/yellow
Ig2 = yellow
any input before I set my car on fire? Thanks.
Trying to install a push start.
Old Aug 27, 2013 | 05:21 PM
teamXteg's Avatar
Default Re: ignition wires. which is which? (97 del sol si)
https://honda-tech.com/forums/showth...button+install
^^ this is a pretty detailed push button install DIY i found a while back.. hopefully it helps
Shaynepolevault
Jan 26, 2008 09:05 AM
lsvtek
Audio / Security / Video
10
Aug 23, 2006 08:56 PM
HamiltonRex
14
Aug 9, 2006 06:07 PM
BoostedH23a1
Nov 3, 2002 07:12 AM
