insane amounts ofcrap for an eg
Suspension
blox 21 mm rear sway bar $120 (used)
eg blox red lcas $45 (used)
blox rear lcs (purple) $100 (new)
dna rear stabilizer (purple) $ 75 (new)
skunk 2 front sway bar 26 mm $150 (used)
skunk 2 rear camber (will sell both sets of camber for $250)
skunk 2 front pro series camber
skunk 2 traction bars $500 (used)
k sport pro coilovers $ 500 (used approx 6k miles )
eibach front and rear sway bar (will sell for 175)
Turbooooooo ( will sell all for a 1100 obo for individual pricing me)
Garrett T3/T04e 50 trim •
eg ic piping
eg fmic
greddy type s bov
greddy type r bov X2
Transmission (will sell clutch and flywheel plus lsd for 450)
OBX LSD
LSD Moto Fly wheel
LSD Moto. Clutch stage 2
Engine for a d16z
z6 engine trans + linkage $250 (approx 180 miles)
SKUNK2 INTAKE MANIFOLD (sold)
heat shielding intake gasket
tial wastegate (pm me)
38mm FJ R Spec Custom Length D16 I Beam Connecting Rods -
ARP 2000 3/8" Rod Bolts -ARP Lube -$ 70 (new)
YCP Vitara pistons (75mm / 75.5mm / 76mm) -(pm me)
Wrist pins and C clips pm me
Piston rings NPR $30 (new)
OEM Timing Belt $20 (new)
Japanese Water Pump $100 (new)
ACL Race Rod Bearings $60 (new)
ACL Main Bearings $60
King Thrust washers $50 (new)
Full engine Gasket & Seals set (pm me)
Metal 3 layer Head gasket approx .30 thick (pm me)
APR Head Studs $90 (new)
BISIMOTO Race Valve Springs and Retainers • $325
Supertech Stainless Valve Set I/E • $85 (new)
Supertech Valve Guides $60 (new)
BISIMOTO LEVEL 3.6 Camshaft • $500 (new)
BISIMOTO Engineering Cam Gears $135 (new)
Blox Cam seal $5 (new)
Golden eagle Fuel Rail • INSTALL KIT
HASPORT ENGINE MOUNT KIT 92-95 $300 (new)
70a • 4 Torco TBO Premium Break-in Oil 30SAE 8 torco sr -1 racing synthetic $30 for all of them i have 20 quarts
machined z6 block has been specd balanced and bored .5 over $600 (have receipts )
Random
jdm headlights w/ amber corners $65 (new)
usdm headlights w/ clear corners $30
leather rsx seats $250 (rails custom to fit eg)
spoon short shifter (sold)
purple nrg quick release 2.5 full setup $275 (minor wear and its purple)
gsr rear disc brake conversion (pm me)
carbon fiber duckbill w/ third brake light $125 (new)
dr-19s (send me a text ill give you all info and pics)
gsr 5's $250 ( sitting on falkens)
momo pedal covers (sold)
eg6 fender set X 2 $30 bucks each (two sets of black)
eg6 hood X1 $50 (black)
ex door panel swaps $100 (for both doors)
water pump $20 (new)
rear tlights eg6 $20 (used)
rear tailights ej1 $20 (used)
call/text 773 954 6952 for pics or more info
eg ic piping
eg fmic
greddy type s bov
OBX LSD
LSD Moto Fly wheel
Engine for a d16z
Random
watch what you buy. I just got in my "jdm headlights" with amber corners....ya they are knock off ebay lights. the amber corners dont even match. one is the darker tinted amber and the other one is bright amber. the bright amber one has a broken tab on it so it wont sit properly now.
Also got the eg6 taillights and there is only ONE of the four that is not cracked all up. Look like they were a last second junkyard pull. damn my ebay cf tails look better.
will be happy to post pics so that everyone can see for themselves if interested.
solsi2000
Jan 8, 2010 04:03 PM
solsi2000
Jun 11, 2009 12:25 PM
