d16z6 question
Old Aug 25, 2013 | 07:10 AM
vtrp2008's Avatar
Default d16z6 question
I got d16z6 in 94 eg coupe...had some surging at idle so took off thrittle body and fitv and sprsyed with carb cleaner and brush and scrubed them clean..adhusted that white circle inside the fitv so it was tight (turned all the way closed). The gaskets broke so i used gasket naker silicone and sealed it up...let it sit for about 14 hours then started it and goes ght to 4k rpm and stays...sprayed carb cleaner while running and didnt make difference....could it be cuz i need the real gaskets and not silicone? and throttle body gasket broke and had to use silicone on that as well...my feeling is the silicone but other thoughts are appreciated...thanks
Old Aug 25, 2013 | 07:19 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: d16z6 question
Yeah get real gaskets they're only a couple of bucks.
Old Aug 25, 2013 | 07:27 AM
vtrp2008's Avatar
They wont be in til weds ill just leave the car sit til then
Old Aug 25, 2013 | 02:42 PM
teamXteg's Avatar
have you tried cleaning the IACV?
Daniel Murillo
Mar 29, 2019 09:15 AM
crx_si-r
Mar 8, 2007 04:05 PM
e jay one
Jan 17, 2007 01:25 PM
stwano
Jul 9, 2006 12:04 PM
