what flywheel are you using?
Old Oct 25, 2002 | 02:27 PM
Accord15's Avatar
Default what flywheel are you using?
To add to my last topic of clutch what flywheel are you guy using. Gonna have the transmission opened up anyway so i might as well throw in the extra money for a flywheel. Thanks
Old Oct 25, 2002 | 02:43 PM
niedejb's Avatar
Default Re: what flywheel are you using? (Accord15)
Unorthodox racing. Best NA mod that there is period.
Old Oct 25, 2002 | 03:41 PM
90AccordEX4Dr's Avatar
New User
Default Re: what flywheel are you using? (niedejb)
I have a Fidanza 8 lb. Aluminum one. I agree with niedejb... one of the best mods you can make. Huge Difference!
Old Oct 25, 2002 | 07:41 PM
Nick M's Avatar
Default Re: what flywheel are you using? (90AccordEX4Dr)
Aasco, they used to make Fidanza's and CM's i believe its 9lbs.
Old Oct 25, 2002 | 07:42 PM
smokin rubber's Avatar
CM 11lbs, very nice
Old Oct 25, 2002 | 09:19 PM
Conechaser's Avatar
Default Re: what flywheel are you using? (smokin rubber)
What kind of prices and where can i look at/order online one?
Old Oct 26, 2002 | 06:10 AM
Default Re: what flywheel are you using? (94Accord)
the CM is on group buy center a lot and is usually ~$300.
Old Oct 26, 2002 | 09:01 AM
Boosthead's Avatar
I have a Clutchmasters. Great mod. ~8 lbs. Revs very quickly. You can find them on group buy center for $300 shipped all of the time
Old Oct 26, 2002 | 12:02 PM
WheAs MaI MojO's Avatar
Default Re: what flywheel are you using? (Boosthead)
OKAY you proffessionalized people! what the heck does a flywheel do? how does it work? why is it good compared to the stock?
Old Oct 26, 2002 | 08:21 PM
WuWarrior's Avatar
how much torque do you loosed with a flywheel 7-9 pounds?
I'm afraid to go below 12 pounds for a flywheel. I love torque
Old Oct 27, 2002 | 10:29 PM
Accord15's Avatar
Default Re: what flywheel are you using? (WuWarrior)
I was wondering this also, have you guys lost any torque?
Old Oct 28, 2002 | 01:27 AM
MrMike's Avatar
u don't lose any torque at all. when ur clutch is fully enganged the flywheels is nothing but rotating mass, mass that ur engine needs to spin. illiminating some of that mass will put more power to the ground because the engine can waste less energy spining the heavy flywheel. Flywheels are heavy from the factory to make it easier for the car to start from a dead stop. with a lightweight flywheel its harder on the clutch to get the car moving since u need to rev higher to have a smooth engagement and upshifts are much smother with out the jolt right when u upshift. Engine will also rev and drop much faster.
Old Oct 28, 2002 | 07:31 AM
TypeSH's Avatar
Default Re: what flywheel are you using? (MrMike)
My question for thsoe w/ lighter flywheels. How did acceleration in the higher gears compare w/ the lighter flywheel vs stock? Based on the technobabble by SCC a while back, lighter flywheels show their benefits with high gear ratios, which makes me think our accord's crappy 4th/5th gears wont take advantage of it very much (and where I spend most of my time driving).
Edgar
37
Aug 15, 2005 12:04 AM
MintFlavored
Apr 27, 2004 06:08 PM
Xecutive
Apr 20, 2004 05:33 AM
IdotheSHOCKER
May 23, 2002 03:10 PM
