b18c1 all motor build
Old Aug 24, 2013 | 08:47 PM
nate1723's Avatar
Default b18c1 all motor build
so i am going to build a all motor b18c1 for my 00 civic. here is the build as of now
Arias pistons 12.8:1 81.5
block hone abd bore to match
Eagle rods
Skunk 2 tuner stage 2 cams
Skunk 2 cam gears
Skunk 2 springs and retainers
Head port and polished
APR head studs
Skunk 2 intake manifold
65mm throttle body
AEM intake
1000cc injectors
Chipped ecu p72
Tuned for e85
sound like a decent build? goal is 200hp for now.
Old Aug 25, 2013 | 08:53 AM
UncleD's Avatar
Default Re: b18c1 all motor build
So you have your grocery list. Now go shopping.
Old Aug 25, 2013 | 07:11 PM
nate1723's Avatar
i already have all parts,
Old Aug 25, 2013 | 08:03 PM
LightWeightChamp's Avatar
shouldnt be an issue to get your goal. injectors are a little overkill. I'd personally go bigger on the TB. Also make sure you have a good header.
good tune and you'll be golden
Old Aug 25, 2013 | 08:53 PM
UncleD's Avatar
So you bought the parts, and then ask if it's ok?
I'll tell you that you spent too much. Usually people will ask before buying and we suggest they look at the dyno thread and search around for similar builds to see what kind of output they made.
I guess some walk before they crawl?
2.0SLEEVED
Dec 11, 2012 05:02 AM
hYbRid_Eg6
36
Feb 1, 2011 10:14 AM
hatchn1.9
15
Dec 15, 2010 02:22 PM
b19coupe
32
Oct 17, 2005 10:58 AM
94DOHCGsr
11
Sep 29, 2005 07:20 AM
