b18c1 Intake Pipe on B18a1
Old Aug 24, 2013 | 09:25 AM
HellaStockEJ6's Avatar
Default DA9 Intake clearance ABS
So i am currently attending a tech school and i have access to 50% off K&N products, so im interested in a intake pipe for my 91 B18a1, now the K&N version for the a1 in the 90-93 still makes use of the oem piping(which i dont want) so i found the 94 GSR intake pipe for a little bit more, filter piping the whole deal, for like 20$ more... my question is will it fit a b18a1 in a DA chassis?
http://www.knfilters.com/search/prod...x?prod=57-3509
Old Aug 25, 2013 | 05:34 AM
Default Re: b18c1 Intake Pipe on B18a1
Come on please, will a DC/EG/EK/EM1 Intake fit a DA and clear my ABS?????
Old Aug 25, 2013 | 08:49 AM
Lord Helmet's Avatar
No because the b18c1 throttle body sits lower then a typical b18a/b intake and isn't a straight pipe design. the dc/eg/ek/em1 will fit but a lil adjustment to clear the battery. Or you can just relocate the battery to the rear and open up the area for more room.
Old Aug 25, 2013 | 09:08 AM
okay , i am relocating my battery to the trunk so with a dc/eg/ek/em1 intake will still clear the abs reservoir on the da?
Old Aug 25, 2013 | 09:22 AM
Yes, my brother in law DA has abs and he just relocated the battery to the rear but his DA is turbo'd though but same concept.
Old Aug 25, 2013 | 10:43 AM
what do you think would be my best choice? i could either go for an eg(like a d16z6) an ek/em1 (d16y8,b16a). they all have different bends, and K&Ns filter for the DC is the same as the GSR (lower tb) but it says it fits all 94-01 tegs. im just skeptical about the ABS, and i dont want to buy one, have it not fit then have to return it, and try another one haha.
Old Aug 28, 2013 | 08:27 AM
So I found a 92-95 civic si intake pretty much a d16z6 so a civic ex one too. It looks like this,
With no battery in the engine bay it seems it follows the same first bend as the stock pipe but continues at an angle instead of curing left to get around the battery.
My guess is it would be somewhat like this If I am correct? Now I know that car has no abs but it looks like it would clear the system , any input? Thanks
Old Aug 28, 2013 | 11:41 AM
B_Swapped93's Avatar
you'll be fine with that intake I still used a AEM SRI on my GSR even tho I had a skunk2 intake manifold. But idk if the OEM one would fit meh probably if you wiggled it around enough or have a tucked/shaved bay.
Old Aug 28, 2013 | 12:08 PM
Yeah I'm pretty sure if I can get like a longer coupler from the tb to intake , I can have some bendable movement ya know?
Ek00em1
Mar 24, 2019 08:48 AM
Honda_ThuGZ
16
Jan 6, 2008 04:53 PM
boostd92
Apr 25, 2007 12:39 PM
testingcheck
Apr 16, 2005 08:01 PM
tianporn
Nov 16, 2004 04:02 AM
