ignition interlock recall
Looking around mine I am not sure they replaced it. Anyone know if there is a witness mark or color to confirm the new one was installed? Is the correct part number for the '03 Ody 54020-S0X-A53?
Thanks.
Thanks.
Sorry, I wrote shift interlock in my original post.
The issue is ignition interlock, as in the thread subject.
I can still remove my key when the shift lever is in other than park position. That means they either didn't do the work or botched the work?
I have had the ignition interlock recall done on my 2004 pilot in July 2013 now my key is stuck in between the 1 and 11 position. I had to unhook my battery to prevent the drain from the key in the ignition. Could this be a bad repair job from the recall? I had no problems before. Thanks!
durangedesign.com
Feb 5, 2003 05:08 PM
