Help me Please. Si 2007 Coupe
I recently bought a 2007 Honda Civic Si with 105k Miles on it. I drove it home and it was very nice and smooth..
Any time I buy a used car I like to change the fluids and do a tune up.
I change the Cabin Filter
Air Filter
Coolant
Transmission Fluid
Oil and Filter
Spark Plugs OEM
Valve Cover
O-Rings
Grommets
and I gently with a slighty drench paper towel in Throttle bottle cleaner clean the Throttle body...
I am now having some Rev Idling issues...Mainly the car continues revving from 1K RPMs to 2.5k RPms as if I was pressing on the gas pedal...Also when I'm in gear there is Jerk move when I let go of the gas pedal
I burped the coolant to make sure i didn't have air.
today I remove the battery cables and restarted it and let it idle (I think perhaps not long enough) Will try to reset and idle tomorrow for a solid 15-20 minutes...
The throttle body 100% needed to be clean. It was coated heavily in carbon. I'm hoping the reset works..Does anyone have any idea what else it could be? Or what I can do. I"m in morris county, NJ. Does anyone know how to calibrate the Throttle Body without having to pay the Dealership..I'm broke right now after buying the car and doing the tune up(Which need it)
Air Filter
Coolant
Transmission Fluid
Oil and Filter
Spark Plugs OEM
Valve Cover
O-Rings
Grommets
The Reset didn't work.
Now I dont know if I need it to have it Calibrate it. Or I should buy one
The damn Auto Revving from 1kRPM to 2.5 RPM after taking it out of gear is obnoxious.
No I am not. When I turn the AC there is small kick feel/sound but I think that's normal. The rpm revving and a little harder jolt when taking foot of gas is annoying. Does only the honda delearship do calibration. Not sure if to buy or Calibrate it
Here is what I did when it came to the reset.
Unplug both battery cables. Left them for a while off
Plug back in and Turn car on (Made sure the AC wasn't running) I let it idle for a good 20 minutes. at first the auto-Revving isn't there. once I get going the Jerk when taking foot of gas and then when I go to neutral the Revving starts on its own. I got a feeling the Throttle has really gone haywire ...
What are some of the things I should worry about? Say I left as is for now? Would it affect any other stuff? Would the worst case just be the obnoxiousness of it?
Oh yeah If I do buy the throttle body! Would it need to be tune into my car?
If the rpms are jumping on its own in park neutral whatever without touching accelerator it could be something other then throttle body. Unless its possessed. Bad injector fuel filter sppark plug cables rattached in wrong order. I've never seen a throttle get messed by cleaning it. Its gotta be something else unless you damaged it during you aerosol session
http://www.8thcivic.com/forums/ecu-t...ttle-body.html
Read that thread, it may answer many of your questions.
I think youre right! I have done a few resets and sometimes it feels better... I definitely feel now that when I'm cruising and its on neutral (The Air flow is pushing the Throttle open ...? I say this because I now got it almost to the point that if I'm stand still it no longer revs itself...***Sigh***I borrowed today my friends 10,000$ Snap On Computer and the best I could do was Reset the PC that way I think it may it a little bit better but still... Gonna hope it gets better. *sigh* so i can start enjoying my baby!
Thanks for your time thought cheeech
