Integra P0715 Code
Recently I got the P0715 CEL on my 96 Integra and I've been so busy that I've been putting it off to fix the issue. Well today I decided I would look into it and pulled out the service manual. According to the service manual, the mainshaft speed sensor needs to have a resistance between 4-600 ohms and I checked it out today and mine came out to be 5.75 M ohms. So if I'm thinking correctly, that makes the sensor way out of spec and it should be replaced correct? Also I removed the 10mm bolt holding the sensor in place but no matter how hard I pulled it would not come out. Is there any trick to removing them?
Finally got the sensor and replaced it and the sensor was no good. I'm glad the transmission was fine. Now I need I replace the inner and outer tie rods.
2002accordv6sdn
Jan 3, 2015 12:53 PM
mar7pau
Aug 29, 2010 10:34 AM
Propulsion
Sep 20, 2004 04:02 AM
