f22b help!!! regarding dizzy wiring / dizzy cap
I have done some research regarding using the internal coil dizzy which i am using from my f22b swap into my 96 accord but am still a little confused.
The car is a 96 accord. It has an external coil. The dizzy im using is from the f22b(sohc) non vtec with internal coil. I understand you have to stretch and wire the 2 sensor wires by the timing belt cover into the distributor. I did that already. I am confused about the black/yellow wire and the blue wire thats coming out of the distributor. Where do those wires go? I am using the 96 accord lx wiring harness. I have read somewhere that i have to splice a two connection plug and a 4 connection plug that i would've used in my external dizzy and wire them to the internal dizzy... I am a dummy when it comes to wiring... please help..
so basically... i have the internal sensors wired up but dont know how to wire anything else up... black/yellow blue wires???? etc...
also my f22b sohc dizzy cap is busted... what usdm cap fits???
azzinine1
Jan 14, 2005 04:57 PM
