H22 swap wont start after changing coil
Ive been battling a weak spark/random misfire issue for a while now, and tonight i decided to change the coil. Im running a jdm H22 distributor with internal coil. Changed it out with an obd2 single cam coil with the same part number TEC TC-08A and it blew #24 fuse. Looked at the wire diagram and found that gsr integras run a 20amp there and my cars an ls with a 15amp which blew so i put in a 20amp. Car cranked up and ran and i started pulling plug wires to check how the spark looked. Car died so i checked the fuse again and its still good. No other fuses are blown. CEL comes on, fuel pump primes, but the battery light does not come on. Im guessing im dealing with a no spark condition but cant confirm because im by myself lol. Anyone have any ideas?
