no brake light
left and right brake light dont work. i check fuse and i replace both bulb, still not working. maybe its the brake light switch ??? when im on cruise control and i push on the brake pedal , cruise control cut off, his that mean the brake light switch is ok ??? any ideas please help me
Check the fuse with an ohmmeter or just replace it.
Have someone step on the brakes and check if you are getting power to the bulb sockets by using a voltmeter.
If you are not getting voltage, there is an open in the wire since you say the switch turns the CC off.
CRX T-Si
16
Jun 23, 2006 11:30 PM
