1990 crx si d15b
I recently bought 1990 crx si it has d15b vetc. The previous owner try to put turbo but never did so I had to put back together I need help with wire problem on the distributor. Their seems to be missing plugs may I have the wrong harness if so how would I know.
I'm having trouble with these two wires yell/grn coming distributor and the white one coming from the harness. (Theirs two white ones and I put one on the distributor)
two white wires, one is ignitor, one is cyp sensor, it wont run right if you get them mixed up, and the sensor under the dist. looks like the coolant temp sensor, does your temp sensor work?
89 CRX SI
27
Jan 20, 2003 04:12 PM
enabi
Aug 8, 2002 05:36 PM
