Brand name review First Equipment Quality
Hey im in need of an upper control arm -driver side for my 02 accord se.
any opinions on this brand name FEQ?- First Equipment Quality
I see it gon for 87 bux on AUTOPARTSWAY.ca
Also any opinions on an OIL PAN, i see MTC as a potential choice
RockAuto has Dorman brand for ~$50
DORMAN Part # 520621 More Info {#51460S1AE01, 51460S84A01, WC120621} Control Arm w/Ball Joint Front Left Upper; Includes Bushings- $51.79
DORMAN Part # 520622 More Info {#51450S1AE01, 51450S84A01, WC120622} Control Arm w/Ball Joint Front Right Upper; Includes Bushings $52.79
As for Oilpans, meh, just go to Honda the price difference for such a critical part is so minimal, might as well get the OEM unit.
Thanks for searching for.
I actually say a MOOG Upper control arm on ebAY for 68 but comes up to 115 with shipping and import charges .
I'm looking for OIL PAN (MTC 61) , REAR STABILIZER BAR END LINKS (MOOG LEFT AND RIGHT FOR 36 EACH) , DRIVER SIDE UPPER CONTROL ARM (68 Moog EBAY).
The brackets are the prices ive seen so far.
i'm lookin for a full set of brakes, rotors and durm brakes also. -
02 accord se 4 cyl. coupe
RockAuto exports, also check with Honda (parts link in my sig), I don't know if they will export to Canada(or see if your local dealer has an online parts section). You know your postal code, I do not.
Thanks. do you know if ROCKAUTO include duties within their shippin fees?
Any recommendations on brake/rotor/drum brake 4 wheel kits?
I see alot of ZINC COated rotors and drum brakes, and drilled/slotted/ blank.
Im a daily driver no tracking here.
Pads like Posi-Quiets Ceramics are fine. They will not dust like the (factory)Nissin units.
Solid rotors are best. More material = more mass for heat sink.
avio
Suspension & Brakes
24
Dec 12, 2020 06:33 PM
