Oem Replacement Rocker Arms
Hey guys.
Im currently refreshing my build, and I have found that my crower stage 3 performance level 5 cams have eaten into my rocker arms.
Im having a hard time finding oem replacement rocker arms (b series vtec (b16b head/pr3)). I don't care if it is an aftermarket set or oem Honda, im just not looking to spend 1700 for the bisimoto set.
If anyone can point me in a direction to find some (website, or some other source) that would be greatly appreciated!
Used oem rockers are the only practical solution. New oem is a fortune and there are not any aftermarket options for direct replacements. Btw, what's a stage 3 level 5 ? Lol
yeah I don't know why they call them this but here is the link
http://www.crower.com/index.php/cams...pair-4456.html
That's pretty funny. According to crower, they recommend the following for these cams:
Extensive cylinder head modification, bigger titanium valves, lightweight valve train, maximum flow carburetion or fuel injection, racing gas (alcohol or nitro), magneto or electronic ignition, performance rod and crank assembly and increased engine clearances are required for maximum benefit.
royal purple HPS still as all the zinc in it. available at summit racing. not too badly priced and i have used it in the past and will use it on my current build.
or, the valvoline racing or the $$$ joe gibbs and brad penn.
Royal Purple, Valvoline VR1
the standard RP is a great oil with plenty of zinc additive based on BITOG research.
then if you want to step it up more there is Brad Penn and Joe Gibbs.
thanks guys. im beyond frustrated right now. I ended up missing an entire race season because of the machine shop I went with. but now im just starting fresh and going for the win next season. replacing these rockers which have been wearing for a while is just one step in the process. I just wish my car was on the road. if anyone has a hookup on a bum b16 head (someone who dropped a valve or something) let me know. I just need the rockers
this is for ITR, i'm not sure if it can fit to b16b
http://www.oemacuraparts.com/parts-c...e-rocker-arm-2
Something to look into is your install height . Make sure your spring is not coil binding we've seen that to be a issues on big lift cams. We had this issue with a custom cam and turned out the customer threw in springs and didn't realized the numbers he was given were based upon a completely different install height vs what his factory setting was.
I know this is a old, However Mobile 1 oil is one of the top shelf oils on the market.!!!! It's not the oil. Stage 3 Camshafts are vert stressful on the valve train period. Excessive cam and rocker wear is going to happen regardless of what oil you use. It's now 2022 and if anyone is looking for new B series rocker arms Skunk2 has them.
phelpsj2
Jan 16, 2012 05:22 PM
Trey
12
Mar 24, 2011 01:06 PM
