Ignition switch causing car to not start ???
Old Aug 20, 2013 | 06:34 AM
99teggsr's Avatar
Default Ignition switch causing car to not start ???
If my ignition switch succesfully turns car into accessory mode, and into "ON", and into "Start" and cranks engine, could it still be bad ???
Old Aug 20, 2013 | 07:29 AM
lsdisk0's Avatar
Default Re: Ignition switch causing car to not start ???
pull off the little metal cappy thing on the top of the intake/throttle body assembly. if, when you crank it, it spits up like vaporized gas/air your dizzy is off point, pull it off and mirror the rotor. pretty much turn it to the same spot like...
(if dizzy is straight up and down and not at an angle)
pin 1
pin 2
flip it so its
pin 2
pin 1
Moog_enep3
Nov 6, 2013 11:03 AM
ashosheh
Honda Civic (2006 - 2015)
Sep 25, 2010 08:03 AM
b00sted4dr
Jul 31, 2006 05:14 PM
crx_88_si
Jan 18, 2006 04:48 AM
ActiveAero
Sep 27, 2004 10:33 AM
