Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Civic - Engine swap, now in Limp mode
Old Aug 20, 2013 | 02:04 AM
tealej2's Avatar
Default 2001 Civic - Engine swap, now in Limp mode
i have a 01 civic bought from a private seller. Its a ex 4dr auto. Well the guy put a new motor in it which is now a dx motor. The car wont rev pass 4000 rpms i keep reading its cuz i have to swap the ecu from a ex to a dx to match the motor. Then i also have to get it reprogrammed at honda.. any info would help plz if i knew the answer i wouldnt ask. Thannka in advance.
Old Aug 20, 2013 | 03:32 AM
tealej2's Avatar
Default Re: NEED HELP 01 CIVIC
Any help
Old Aug 20, 2013 | 02:28 PM
tealej2's Avatar
Thanks for no help
Old Aug 20, 2013 | 02:33 PM
Caddytech's Avatar
Im sure thats true. The ex and dx engines are not the same so neither is the ECM
Old Aug 20, 2013 | 06:49 PM
toyomatt84's Avatar
Sanji
Originally Posted by tealej2
Thanks for no help
You waited a whopping 12 hours to bump this thread twice, complaining that you received no help. You do realize that this forum is not a business, right? People come and go as they see fit, they're not employed to be on here 24/7. So, the fact that you hadn't seen something for only 12 hours... really doesn't shock me at all. If you received no reply after a couple days, then I'd start feeling more disappointed.
As for your request, you should have a CEL code displayed for the car to be in Limp mode (aka. not revving past 4,000 RPM's). But, from what you've described, you already know your problem. You have mismatched the ECU and engine platforms (VTEC ECU requires a couple things that your non-VTEC engine cannot supply). Get a non-VTEC ECU and have it re-programmed at a dealership to get the immobilizer functioning, and you should be fine.
A/T/Automotive
Mar 24, 2016 06:16 PM
Sickcpe
Dec 23, 2014 11:18 PM
Hawkman13
18
Mar 25, 2009 04:05 PM
DennisWaller
Apr 23, 2007 03:23 PM
The_Robster
May 21, 2002 08:45 PM
