got a 91 civic ef si
hey everyone i got a civic ef 3 weeks ago. It ran fine for the pass 3 weeks until all of the sudden this weekend i was driving CEL and car turns off.It wont start the car the engine turns fast but no start. Brought it to a shop they said the ECU is broken. Any upgraded ecu's i could use for my 91 civic si?
Also what would the cause of the ECu to break on me all of the sudden?
Thanks
Thanks
im not to sure how can i check ? Also i found a Ecu on ebay i think its the same one as mine pm6 something . Also i dont know all that much about cars. But i got it inspected and person said the timing belt looked pretty new as well as the spark plugs i bought this car 2nd hand. Thanks again !
Okay, first thing's first, SEARCH. There's a DIY "Why Won't My Car Start" (or whatever) on this forum for these very cars...
2nd, pull the carpet back off the ecu cover plate in the passenger footwell. If the ECU light is solid, not blinking but just completely solid, then it's bad.
3rd, can you hear the fuel pump prime? Turn the key to the "ON" position and listen for a noise coming from the rear compartment, should be easily heard if it's quiet outside.
4th, PM6 is the ECU that the Si's used. They shouldnt be too hard to find, usually cost around $100.
