96 accord 2.2 vtec misfire issues
Old Aug 19, 2013 | 04:34 PM
ooopseyesharted's Avatar
Default 96 accord 2.2 vtec misfire issues
my 96 accord ex wagon has been excellent for years until the day before my wedding day this past friday. The check engine light would start blinking for a few seconds and then it would just stay solid. It did this over and over again. It started running rough when taking off slowly from stoplights and also when cruising at any speed for more than a few seconds.
It needed a tuneup so I replaced the plugs, wires, cap and rotor.
I guess my questions are these:
1. Before I pay someone $450 to replace the crank sensor, is there something else I should be checking?
2. Is the sensor something I could change myself?
Any help would be appreciated
Old Aug 19, 2013 | 05:40 PM
mrj_accord's Avatar
Default Re: 96 accord 2.2 vtec misfire issues
could be a clogged egr valve or a bad o2 sensor.
have u tried jumping the plug under the glove box and count the blinks for the codes ur getting?
Old Aug 19, 2013 | 05:55 PM
its obd2. it had 2&4 random misfire and crank position sensor. I replaced the egr 8 months ago
Old Aug 20, 2013 | 01:45 AM
holmesnmanny's Avatar
erase the code and pull the egr valve connector and drive it around for a couple days....after a day or so it will throw the egr code....drive it like that and see if the troubles go away and the ckp sensor code doesn't come back....if it doesn't, clean out the egr ports and egr valve
Old Aug 20, 2013 | 03:25 AM
ok. I will try that. th anks
Old Aug 20, 2013 | 06:44 AM
I figured after watching a video on YouTube, I would clean the egr passages. it completely fixed the issues!!!!! it was packed full.
Thanks for the help everybody!
Patk
Oct 19, 2013 01:22 PM
ce1 boy
Transmission & Drivetrain
Nov 25, 2012 12:57 PM
mudpuppy4life
Sep 10, 2011 04:40 PM
hndriver
Jul 19, 2008 08:37 PM
pnut
Jul 27, 2003 08:19 PM
