Transmission & Drivetrain Gearboxes, Differentials, Clutches
Shifter wiggles around...
Old Aug 19, 2013 | 03:17 PM
sir_crx_says's Avatar
Default Shifter wiggles around...
I drive a b16a-swapped 1990 crx with a ys1 transmission. The problem I'm experiencing (one of them anyways...) is the shifter wiggles around, even when in gear. Due to this, I sometimes push into the wrong gear when attempting to shift quickly. I'm not terribly familiar with transmission or shifter parts, but it appears the shifter is the wrong size for the shifter housing, (the ball on the shifter seems too small for the housing).
My question is, what kind of shifter and shifter housing should I purchase to replace this defective part? Any help or advice would be very much appreciated.
Thanks!
Old Aug 19, 2013 | 03:23 PM
wicked_jeb's Avatar
Default Re: Shifter wiggles around...
would also like to know this. my b16a eg hatch does the same thing.
Old Aug 20, 2013 | 04:41 PM
wicked_jeb's Avatar
bump
Old Aug 21, 2013 | 05:36 AM
mugen4door's Avatar
my 95 ls does the same thing i was told it was a shifter bearing
Old Aug 30, 2013 | 07:54 AM
accorse07's Avatar
Try changing out your shifter bushings. The wiggle in your stick may be due to a corroded and old bushing.
If this has already been changed out...it could be due to an extended shifter.
When using a circuit hero, fastline, hybrid shifter...the extended arm will make a small play seem much larger.
BDM
Sep 24, 2009 02:16 AM
jb0705
Jul 10, 2009 12:39 PM
dRoPpEd lS
Mar 9, 2009 09:02 PM
slash00R
Nov 1, 2004 07:23 PM
