Honda CR-V & Element 2WD & 4WD Element & CR-V
1997 CRV FI E/M fuse keeps blowing, car won't run
Old Aug 19, 2013 | 05:14 AM
Weez1's Avatar
Default 1997 CRV FI E/M fuse keeps blowing, car won't run
Wifes CRV was putting out 18 volts, planned to change the alternator but before I had a chnce she need to drive it and it quit on her... Just before dying: wipers, fan blower & blinkers starter working without command, the car died and she pulled off to the side of the road. The battery was smoking a little.
Now, it won't start. The wipers and blower motor work when selected. There is no spark on the plugs and the FI E/M fuse keeps blowing.
Note, the mesh looking connector on the exhaust just under the front door is 1/2 disintegrated (this exhaust problem has existed for about a week and was planned to be fixed tomorrow).
Before replacing the alternator, I need to figure out how to solve the FI E/M fuse issue, please help!
Old Aug 19, 2013 | 02:16 PM
Weez1's Avatar
Default Re: 1997 CRV FI E/M fuse keeps blowing, car won't run
No ideas anyone??
Anybody know if a PCM from a Civic is the same as a CRV??
Old Aug 19, 2013 | 03:50 PM
kiseliok's Avatar
My guess is that you have some wires that melted together and now you are shorting out and therefore blowing the fuse. Might be a bitch to trace that down. :/
Old Aug 20, 2013 | 05:48 PM
Weez1's Avatar
i was thinking burnt wire also... another interesting finding to mention, with the PGM-FI main relay harness disconnected, the fuse doesn't blow. changed the relay, plugged in the new one and fuse blew again??
Old Aug 21, 2013 | 01:21 AM
Weez1's Avatar
Old Aug 21, 2013 | 04:36 PM
Weez1's Avatar
found the problem, pcm. replaced it & fuse doesn't blow, car starts.
now to replace the alternator... that's a bugger for space to get out
Old Aug 24, 2013 | 02:34 PM
Weez1's Avatar
PCM changed, new alternator, new battery and shes alive! But now the engine light is on, the SRS light is on, and the ABS light is on, and the SRS fuse keeps blowing??
Any ideas?
Old Aug 24, 2013 | 04:28 PM
squeaks's Avatar
Have you pulled the codes?
Old Aug 26, 2013 | 05:11 PM
powerfulperformance's Avatar
check your rear o2 sensor wiring. Last time this happen to me so because of that....
rlh781
May 2, 2018 07:10 AM
Mychal71
Sep 10, 2006 02:01 PM
95civicSirCoupe
Sep 10, 2006 04:02 AM
GRLwitDELSOL
Oct 27, 2003 06:31 PM
GRLwitDELSOL
Oct 27, 2003 06:23 PM
