EF Si doesnt idle correctly
Old Aug 18, 2013 | 09:59 PM
egcoupekid's Avatar
Icon2 EF Si doesnt idle correctly
this si has been sitting for 2 years with a broken timing belt, bought it, towed it home, put a belt on started it up wont idle unless you give it gas. wasn't in time SO I finally got it in time after countless trial and errors trying to make it perfect. finally got it to idle correctly 1k UNTILL it gets warms then its around 400 then stops on its own? I did change out the oil, water pump and annifreeze. iacv? fast idle? not really sure how to check to make sure these are the problems?
Old Aug 18, 2013 | 10:10 PM
egcoupekid's Avatar
Default Re: EF Si doesnt idle correctly
gas is also two years old but did not smell stale.
Old Aug 18, 2013 | 10:30 PM
EFlovin''s Avatar
You should take out gas you can, change the fuel filter,change the spark plugs and possibly wires, check TPS, check IAVC and go from there.
Old Aug 18, 2013 | 10:36 PM
egcoupekid's Avatar
gonna change the fuel tomorrow. put a couple gallons of premium in with some stp additives and gonna take your advice. would like to know how much psi my fuel pump is pushin
Old Aug 19, 2013 | 08:09 PM
Nooch's Avatar
I read the top post, I wouldn't think it to be the gas but it would definitely help to switch it.
Octane boosters are 100% useless, don't expect anything... the best rated ones in real world add only ~1 at absolute most. Don't waste your money on them.
Your fuel pump should be pushing ~35 PSI, if not, first run some Sea Foam through the system, then recheck it. Go from there -> fuel filter -> injectors -> fuel pump
that is, of course, if you suspect it to be a fuel problem.
Old Aug 20, 2013 | 09:03 PM
egcoupekid's Avatar
just thought of this. would a vacuum leak cause idle problems. since its obd0 theres a lot of vacuum lines. I didn't see any unconnected hoses but its hard to look back there. I did change the fuel with stp additives and I didn't notice a big difference...
Old Aug 21, 2013 | 01:14 AM
Empsi's Avatar
Yeah I'm pretty sure a vacuum leak would cause idle problems. I bad enough one could cause it to turn off. I suspect it has something to do with spark. I would check the ignition system and the charging system. I would also check the ignition coil.
Michael Booth
Jan 22, 2018 11:26 AM
Jayycock_DA9
Feb 28, 2013 04:35 AM
Mik3
Feb 5, 2006 06:55 PM
gooberwolf
Apr 15, 2004 09:02 AM
gooberwolf
Aug 6, 2003 01:59 PM
