Honda CR-V & Element 2WD & 4WD Element & CR-V
painting taillights
Old Aug 18, 2013 | 08:26 PM
jayjazmin's Avatar
Default painting taillights
Hey guys, I got a 1st gen crv. Looking into painting taillights to get the all red and clear look. Picked up some duplicolor metalcast but not too sure which clear I should pick up. Does anyone have suggestions on what and where to buy? Thanks
Old Aug 18, 2013 | 08:39 PM
jayjazmin's Avatar
Default Re: painting taillights
Also, would you recommend using the adhesive promoter as well.. im not planningto sand Iit.. was just wanting to paint, then clear it..
Old Aug 18, 2013 | 09:05 PM
jayjazmin's Avatar
I purchased this clear. Not sure if itll work though. Doesnt say uv resistent only nonyellowing
Old Aug 19, 2013 | 03:01 AM
Sticker Bomb's Avatar
Well if you still have the oem tail lights, painting the tail lights with normal paint, will make it none see threw. You need to use VHT paint, as it's tint paint. If you want the red and clear tails, buy them off ebay. If you wanted to go with all red, you can buy red tint paint from VHT, or buy red vinyl film for it (which I sell) for getting the all red look.
Old Aug 19, 2013 | 06:41 AM
jayjazmin's Avatar
Huh? No im using duplicolor metalcast anodized red.. its a red clear..
Old Aug 19, 2013 | 07:25 AM
kiseliok's Avatar
I'm curious how this is going to come out...
Just put film over mine so when I want to change it - I can just peel it.
Old Aug 19, 2013 | 08:18 AM
jayjazmin's Avatar
Pretty much like this.. he mentions duplicolor automotive clear coat. But not sure which one he uses..
http://www.iwsti.com/forums/gr-exterior/154382-painted-red-tails-another-one-31.html
Old Aug 19, 2013 | 10:25 AM
kiseliok's Avatar
oh whoa. Look at the last post on that page. That red is awesome.
Old Aug 19, 2013 | 10:49 AM
CarGuy91's Avatar
I used red nightshade with rustoleum crystal clear coat...
Old Aug 19, 2013 | 04:45 PM
jayjazmin's Avatar
Did u do any prep work as far as sanding? .. and any way I can get a close up shot?
Old Aug 19, 2013 | 06:43 PM
CarGuy91's Avatar
No prep work other than cleaning with wax & grease remover. Here's a close up..
Old Aug 19, 2013 | 06:44 PM
CarGuy91's Avatar
Old Aug 19, 2013 | 08:56 PM
mrnicolas's Avatar
http://www.iwsti.com/forums/gr-exter...er-one-31.html
that actually looks REALLY good. I am surprised.
Old Aug 20, 2013 | 05:03 AM
77777's Avatar
yeah these are cool, i ordered some tint im going to do mine. looks way better than the red clear ebay ones.
Old Aug 20, 2013 | 06:40 AM
jayjazmin's Avatar
I agree. Not a fan of the depo style.. will most likely be doing mine today. Ill post pics. Was going to do it yesterday but ended up plastidipping rims
Old Aug 20, 2013 | 06:46 AM
77777's Avatar
i like it, just this is way better looking. and cheaper!
Old Aug 20, 2013 | 02:16 PM
jayjazmin's Avatar
Taillights are done. Pix will be up later. Need to hit it with some compound polish n wax still
Old Aug 20, 2013 | 07:15 PM
jayjazmin's Avatar
Old Aug 20, 2013 | 07:33 PM
squeaks's Avatar
Wow those look great
Old Aug 20, 2013 | 07:41 PM
jayjazmin's Avatar
Thanks! Duplicolor ftw!
Old Aug 21, 2013 | 01:57 AM
ekfergie's Avatar
Just curious, did you have to do much wet sanding on those....they look really glossy!
Old Aug 21, 2013 | 02:46 AM
boliviansol's Avatar
Nice ! !
Old Aug 21, 2013 | 02:54 AM
Looks good.
Old Aug 21, 2013 | 07:22 AM
jayjazmin's Avatar
No wet sanding at all. Two light coats of duplicolor metalcast. Then one heavy coat. 10-15 minutes dry time in between each coat. Then waited 30 minutes to apply clear. I didnt use the rustoleum clear. I used duplicolor perfect match gloss. I applied 2 light coats and 2 medium coats. After final coat I let it sit in sun for about 3 hours. Only because it was starting to fog up and having it sit in sun cleared it right up. Then I hit it with compound, polish and then waxed.
Old Aug 22, 2013 | 02:35 AM
CarGuy91's Avatar
Good job, came out awesome
Fuster_Cluck
Oct 28, 2004 01:52 PM
del.soul.
13
May 12, 2004 06:58 AM
JLange
Mar 21, 2003 08:15 AM
T_Rex
Oct 7, 2002 12:22 AM
ludacris
Aug 12, 2001 12:17 PM
