Still running rich - still can't pass smog...HELP!
Old Oct 25, 2002 | 11:57 AM
02WRX's Avatar
Default Still running rich - still can't pass smog...HELP!
This is a JDM b16a in a 90 Civic EX.
Ok, I've now done a obd1 conversion (p28 ECU jumperable done by Katman/GSR dizzy/OBD0 injectors running through the resistor box still). I just replaced the cat. New cap & rotor as well.
I'm still throwing out about 220-300 ppm on Hydrocarbons when running off the stock p28 program. My CO is fine when running the stock program. My A/F gauge runs in the green, then will dip all the way to full lean for a moment, then come back up - no change in the rpm's, but there is an notable audible difference when it cycles through like that.
Any ideas? I'm close to giving up, trying to sell the car to someone in a state that doesn't smog check & buying a WRX at this point.
Eric
Old Oct 25, 2002 | 12:09 PM
PnX-R's Avatar
Default Re: Still running rich - still can't pass smog...HELP! (90CivicEX)
O2 sensor or ECT sensor...
If the ECT sensor is faulty, the ECU will keep on dumping in fuel..
And about the meter.. Did you happen to tap into any sensor when installing it.. I don't know much but I do know that the ECU looks for resistance from sensors.. And by adding the meter in series or parallel, it'll change the resistance of the circuit and probably give the ECU bogus readings..
[Modified by PnX-R, 3:11 PM 10/25/2002]
Old Oct 25, 2002 | 01:45 PM
Urban Business
Guest
Posts: n/a
Default Re: Still running rich - still can't pass smog...HELP! (PnX-R)
yep better off running a 2nd of sensor for the guages. this is how i destroy o2 sensors and throw codes every 5 min. way too many guages running off my o2
Old Oct 25, 2002 | 05:01 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Still running rich - still can't pass smog...HELP! (TorteX)
unplug one injector -1/4 the emissons
Blaze
Cesar_gsr
Jan 12, 2013 08:06 AM
erikiksaz1
Feb 10, 2007 07:16 PM
Reelizmpro
Aug 13, 2006 07:18 PM
Colin
Jan 9, 2003 12:32 AM
Projectg2i
Dec 16, 2002 02:30 AM
