What are the best coilovers for your integra?
I've been looking around the web for coilovers as my Integra is desperate for some low as its currently a honbaru (Honda chassis/Subaru height).
As I've been looking i've seen D2 RS's, Skunk 2 Pro C's and S's, K sports, Tein super streets and all that. Now as i've pretty much never had any experience in Coilovers, I was asking what ones would you all prefer? and if there is one that I haven't mentioned, maybe you could add in your preference.
I was looking at coilovers around the $800 - $1,300 mark. Just seeing whats out there, so when I'm ready to buy, I can just jump on it.
if daily drive or auto x then koni ground control with spring rate of your choice, if drag go with progress, for slam or flush go with function and form. there are better one out there but for your budget those are what i go for.
Posted from Honda-tech.com App for Android
From: Pensacola, FL and every Court House in Louisiana
Ones that work!!!! Spend a little time in the suspension section as this topic is covered on a weekly basis. At that budget AMR would be the only option. Custom built coilovers for your exact setup!!!
As far as the companies you mentioned, I wouldn't touch a single one of those.
after reading about amr I agree with the above. for a solid performing, well reviewed coil over, you cant beat amr. sure it takes a while to get them, but I think theyll be worth it
FRKWOO
30
Nov 7, 2009 04:34 PM
projectkleee
Suspension & Brakes
10
Aug 15, 2007 02:44 AM
