What cams and gears are these?
Old Aug 17, 2013 | 12:13 PM
guy_from_nerk's Avatar
Default What cams and gears are these?
I believe the cams are just stock b16's but they have MA engraved on the ends of them. Not sure if that's a factory Honda engraving or not (I've never ran stock b16 cams). Also not sure what brand these gears are, hoping maybe someone on here knows
Top of the cam has M A on it
Gears
Old Aug 17, 2013 | 01:06 PM
Runnerdown's Avatar
Default Re: What cams and gears are these?
Stock b16 cams never had MA engraved so they are likely not stock. As far as the cam gears go those are old school style. Many jdm company's back in the day used that kind of gear which is a stock sprocket machined and fitted with the adjustable center.
Old Aug 17, 2013 | 04:30 PM
Hmm wonder what the MA stands for. The gears have no markings that I saw
Old Aug 17, 2013 | 08:05 PM
TheShodan's Avatar
Moderator
Specifically an "old school" JUN Cam Gear Circa 1996 .
As for the engraving... who knows.
Old Aug 17, 2013 | 08:15 PM
Are you saying it's a JUN gear or just looks similar to one? The motor we pulled the cams out of also had a Spoon intake manifold gasket and a sleeved bottom end. I am assuming someone put some money into this thing at some point. The cams look like stock b16s on the rings, but someone above mentioned the stock ones never had M A engraved on them. I will snap a better pic of the cams in a few minutes and post
Old Aug 17, 2013 | 08:32 PM
Gears look like stock modified, but by who? The cams look like b16 but the engraving is still throwing me off
Old Aug 18, 2013 | 02:20 AM
92civiceg9gsr's Avatar
Definitely JUN cam gears. The only way to know anything about the cams is to degree them measure their lift/duration.
Old Aug 18, 2013 | 07:02 AM
Gunmetal_B20_Hatch's Avatar
JUN gears for sure...
Old Aug 18, 2013 | 08:41 AM
We're gonna measure the vtec lobes tomorrow and i'll report back with measurements
Old Aug 18, 2013 | 12:43 PM
jimmysxxl's Avatar
I fell in love with those cam gears the moment i saw them..They are so Era correct ^_^
Old Aug 18, 2013 | 02:33 PM
How much do you love them? They are most likely going up for sale
Old Oct 14, 2013 | 04:07 PM
Had a buddy mic the cams for us today, this is what he came back with
Lobe Measurement:
Exhaust
1.36in vtec
34.55mm
Intake
1.38
35.05mm
Old Oct 14, 2013 | 05:12 PM
F22Master's Avatar
You need to measure the base circle of the lobe and subtract that from the highest part. That will give you your lift.
Old Oct 21, 2013 | 11:13 AM
Small lobe on intake reads:
1.382-1.253= .129"
35mm
So 35-31.7= 3.3mm
Exhaust in inches:
1.36-1.236= .124"
In mm it's:
34.76-31.36=3.4
I am thinking we measured something wrong lol
Old Oct 21, 2013 | 11:24 AM
d15Beta's Avatar
where u measured the highest lobe (midle lobe) is peak
base circle is the bottom of it so u measure by rotating that cam about 90-95degrees base circle that would be...
Old Oct 21, 2013 | 11:42 AM
UncleD's Avatar
Those cam gears are useless without any timing marks on them.
My cam gears are engraved
Old Oct 21, 2013 | 12:31 PM
Umm they are engraved lol, the white has faded. Look closely at the top of the gear, if you don't see it, i'll use MS Paint and circle it for ya haha
Gears
Old Oct 21, 2013 | 01:40 PM
UncleD's Avatar
Ohhh now I see. Wheres the mark on the teeth?
Old Oct 21, 2013 | 02:32 PM
d15Beta's Avatar
at 7'0clock
Old Oct 21, 2013 | 05:22 PM
UncleD's Avatar
Ohh yeah I see it now. Wow wtf is going on with these things? LOL!
guy_from_nerk
Oct 20, 2013 07:30 AM
twiztid00002
Feb 5, 2009 12:01 PM
AznCzs
Jun 6, 2006 05:57 PM
fastludeh22
Jul 30, 2003 08:46 AM
