Water coming in around rear view mirror and in passenger floorboard.
Old Aug 16, 2013 | 05:40 PM
Black R's Avatar
25 Year Member
Default Water coming in around rear view mirror and in passenger floorboard.
I've been chasing this problem for a while.
I removed the sunroof and Plugged the hole.
I resealed the plug / plate under the cowl.
And I put silicone around the windshield seal.
What else could it be?
Old Aug 16, 2013 | 09:11 PM
Nottjbarlow's Avatar
Default Re: Water coming in around rear view mirror and in passenger floorboard.
Heater core for floor board water????
Old Aug 16, 2013 | 09:15 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
what do you mean you plugged the hole where the sunroof was, thats the only thing high enough to leak water around the mirror, and silicone on top of the windshield urethane wont do anything
Old Aug 18, 2013 | 07:40 AM
Black R's Avatar
25 Year Member
I mean I removed the sunroof completely (to save weight):
I used outdoor double sided tape and silicone to seal it.
I checked the sunroof drain tubes and only the rear ones were clogged - the front ones were fine.
I think I pretty much found the source of the leak though: there was enough of a looseness in the windshield for me to pry it up at the passenger side upper corner, so I lifted it up and window sealed as much as I could as a temporary fix.
I'm going to take it to a windshield repair shop and get them to reseal the whole windshield to be sure though.
Old Nov 30, 2016 | 01:13 PM
Black R's Avatar
25 Year Member
I thought I had this beat when I has the windshield seals redone.
But it now it's back again today after a downpour:
(Click to see video.)
W T F ?!
This is all from today after some ridiculous storm - I come out after work and start driving.
First stoplight I come to = where is all this water coming from?!
Old Nov 30, 2016 | 03:37 PM
matt965's Avatar
I had that happen to me on my first hatch. My leaks were mostly at the front where cables and pipes for the heater core were supposed to come through and also where the hood release cable ran through (it was very badly gutted I know...). I would look around those areas and also around the fresh air vents underneath the wiper transmission.
Old Dec 2, 2016 | 08:01 AM
Black R's Avatar
25 Year Member
I got a cel code 16 while limping the car home - it started randomly sputtering and running like **** while the tach jumped around all crazy and the wideband gauge also gave some crazy erratic readings.
I removed the hondata s300 ecu and conversion harness and took them in the house to check them out and inspect for water damage. I found evidence of moisture on a couple of the pins in the connector for the conversion harness and dried them out.
​​​​​​​I hope nothing is fried!
I bailed about one gallon of water from the rear floorboard on the drivers side and another half gallon of water from the rear floorboard on the passenger side.
I checked the rear window seals and found that the screws holding the window hinge to the b-pillar were not tight - the seating to the chassis is a bit stripped. This is the suspect area IMO.
I decided to drill three small holes in the chassis to prevent future water pooling issues:
One behind each seat in the rear floorboard, and one in the spare tire well.
I peeled off the roof gutter trim on drivers side and inspected the area - no evidence of a crack or leak there.
I'm going to check the inside of the roof panel today and report back.
Old Dec 2, 2016 | 03:34 PM
Tyson's Avatar
Jesus man you got tidal waves in your car....
Wet your car with a hose and use compressed air with a thin nozzle to jet air from inside the car, out. See if you can spot any bubbles on the outside, like around your windshield or gutter rail or sunroof or antenna hole or rear washer fluid.
I wouldn't rule out fresh air intakes for the HVAC and the left vent one.
Old Dec 2, 2016 | 05:57 PM
schueytenten's Avatar
Damn, that is exactly what I was saying. I can only be happy for my "little" leak. I have nothing to bitch about. That looked like a gallon of water sloshing around in there.
Old Dec 4, 2016 | 05:23 PM
Black R's Avatar
25 Year Member
I've already checked all seals and siliconed everything under the cowl and hvac area.
I'm pretty sure it's the rear window seals at the b-pillar hinge and now maybe a small leak at the tail lights.
thewrai6th
Feb 17, 2017 09:50 AM
awdgsx96
Oct 30, 2007 02:39 AM
BadEH2
Mar 24, 2005 09:59 AM
hOndafienD 04
Dec 9, 2004 11:13 AM
JTCdudeman
Feb 17, 2003 05:48 AM
