P.R.E. Stock sleeve B20VTEC Dyno
Just got back from a dyno session of a motor that I built for a friend of mine. Really simple build with nice parts. Setup has been running on a street tune for 2 years now and he has finally gotten around to getting it strapped down. I want to congratulate him for going through with the build and going/listening to my suggestions on parts selection. I am proud to be a part of another motor build that puts out power!
Setup consists of:
B20 Block
RS ITR Pistons
Stock B20 crank
Stock B20 rods w/ARP Bolts
RLZ GSR Head
Skunk2 Pro VT
Supertech Flat Faced Nitrided Valves
Skunk2 Pro Series Cams
SMSP Header
Here's the graph:
Setup consists of:
B20 Block
RS ITR Pistons
Stock B20 crank
RLZ GSR Head
Skunk2 Pro VT
SMSP Header
Here's the graph:
Yeah Rocket the RS Machine pistons are based on the US ITR piston and come in around 3.5cc.slowsleeper its good to see someone else show what different intake to exhaust cam profiles can do
we're both making the exact 257whp on a 85x89 on 91oct through an exhaust. that just shows that quality companies/parts will always deliver the same/good results (RLZ, Skunk2, SMSP). good work Tou!
awesome to see the power being put down on stock b20 sleeves
I did research on those pistons and I found they were 1.3cc domes.
But of course the head used, milling, and HG will make the final CR
Impressive non the less! Im curious on cam setting, timing, and fuel
He's using Skunk Tuner gears
pump premium
Your wording was kindof mis leading, But i know what you ment, or at least i think you know what you ment to say.. But i wanted to get a better clear up of it for everyone else.
You can ask Black DC4 my recommendations upon this same exact cam combo, as i recommended it to him a year or so ago. I'm sorry "IMPLIED" knoweldge isn't exactly always noticeable here..
also according to zeal, this compression is around 12.1-12.5?
Was a very simple question.. for someone who's out to help the world, i would think you'd jump at a chance to lay some knowledge on me. Your response actually made you sound a bit like bisimoto there for a second.. but if you dont wanna respond you dont have to, your right.
Anyways, what he means by "trick" the engine into thinking it has more compression actually means: using a smaller duration exhaust lobe so your fresh intake charge isn't going right out the exhaust by over-scavenging therefore increasing potential trapped VE%.
