Reverse lights don't work correct 02 Accord
Old Aug 16, 2013 | 11:27 AM
SlamsItIn's Avatar
Icon2 Reverse lights don't work correct 02 Accord
My reverse lights come on when I'm switching into reverse but when I'm in reverse they turn off. It's like I need to keep it just almost out of gear when backing up for the lights to stay on. It isn't a huge problem but I find its a safety issue when backing out of parking spots or into on coming traffic.
UPDATE: it's an AT. It's not the bulbs, fuses or switch because the reverse indicator and reverse lights do come on when I hold the shifter just above the "R" position. Seems like it needs an adjustment somewhere.
Anyone found a solution for this or have any ideas how to fix this?
Old Aug 16, 2013 | 08:03 PM
jdowen2's Avatar
Default Re: Reverse lights don't work correct 02 Accord
You could try and adjust the shift cable a bit or the transmission range switch could be bad.
Old Aug 17, 2013 | 09:38 AM
SlamsItIn's Avatar
I can't believe the trans switch is bad because its working but just not in the right position. Seems more like the shifter cable or something needs tightening or adjusting. I asked the previous owner and they've had the issue all along, someone else must of had this problem. After searching all over I can only find ppl that needed to replace bulbs, switch or fuse that I know are ok on my vehicle
Mesek_oner
Jun 2, 2013 06:33 AM
russianswty
Mar 6, 2007 12:13 PM
94accordstck
Feb 21, 2007 11:29 PM
. M i c h a e l
May 15, 2006 01:12 PM
