1999 Acura Intregra GS-R Help ?
Old Aug 15, 2013 | 08:10 AM
GS-Rb18c1@meets's Avatar
Icon2 1999 Acura Intregra GS-R Help ?
I have a 99 integra GS-R,
Stock
Cold Air intake (pipe running under the bumper for real cold air )
muffler
no headers yet or IM
b16 tranny
Stage 1 coming soon with flywheel
How well do you guys think my performance will be now that i am replacing my:
P/S Fluid/ all fluids..trans,brake,clutch,
new engine mount
new trans mount
new rack and pinion
new control arm assy
new rear cont. arm bushings
Old Aug 15, 2013 | 08:57 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: 1999 Acura Intregra GS-R Help ?
You havent done anything to improve performance so Stock!!! Dual exhaust, headers...
Old Aug 15, 2013 | 12:35 PM
B_Swapped93's Avatar
The ONLYTHING, I can see that may actually help you is the mounts if yours are worn. everything else is just a mandatory maintenance thing. dual exhaust ?? really ?
Old Aug 15, 2013 | 01:28 PM
Yeah, weird.. me an my friend replace the axles with brand new ones and the trans motor mount. Then after the installation the car started to shack and vibrate when accelerating. I took it to the shop that i have been using for 7 years and they said it was my engine and trans mount along with inner tie rods ( the whole assembly). It just seems irrelevant that all this happened right after i replaced the axles. Anyways, since my mounts will now be properly mounted it should allow more acceleration to the wheels. ( as stock should be )
Old Aug 15, 2013 | 01:34 PM
So far i did adjust my timing, and have seen improvements. At the norcal races here in the valley my gsr already pulled on a 5.0 mustang and a 08 honda si.. 5.0 was not a shitty driver, Its a shame when people cant drive
Old Aug 15, 2013 | 01:40 PM
ditch the dual exhaust srsly.....weight reduction y0 !
Old Aug 15, 2013 | 02:04 PM
oh hahahha i just realized that,,, bahahah my bad , no dual exhaust just a lil dual muffler welded on.
Old Aug 15, 2013 | 04:06 PM
Harry3's Avatar
It probably won't get faster, but it will probably feel better.
Old Aug 15, 2013 | 06:32 PM
NameGoesHere's Avatar
Yup yup, pretty much.
I don't see where he mentioned installing a dual exhaust? Just someone "recommended" it haha.
Tooooslow
Transmission & Drivetrain
15
Jun 22, 2015 04:15 AM
wicked200
Jul 15, 2009 02:44 PM
garados
Jan 24, 2004 07:46 PM
tylerdurden
Jul 6, 2003 03:59 PM
