Need urgent help.
Old Aug 12, 2013 | 07:47 PM
Teggiemonster's Avatar
Default Need urgent help.
I have a teg b18b1 and oil is in where my spark plugs are. I have a full gasket set for head and I am trying to get help to properly fix it. I don't want to mess it up. Please help.
Old Aug 12, 2013 | 09:17 PM
B_Swapped93's Avatar
Default Re: Need urgent help.
More then likly just the rubber washers around the spark plug tubes need replacing not a big deal or a costly one
Old Aug 12, 2013 | 10:09 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
Word, what b swapped said. Couple bucks will fix your problem.
Old Aug 13, 2013 | 01:28 AM
HondaPartsHero's Avatar
Technical Hero
http://www.team-integra.net/forum/bl...placement.html
Old Aug 13, 2013 | 05:33 AM
Eg.ls.turbo's Avatar
Take off ur valve cover and flip it upside down and change out those o rings for the spark plugs. This happen to me a month ago, oil filled up my spark plug tube and changes out gasket and fixed it
Old Aug 13, 2013 | 06:43 AM
Do I have to use any of the sealant stuff on it of just the seals? And thank you
Old Aug 13, 2013 | 06:44 AM
Thanks
Thanks
Old Aug 13, 2013 | 06:45 AM
Originally Posted by HondaPartsHero
Thanks
Old Aug 13, 2013 | 08:12 AM
Yes u can if you'd like. I do it just in case, just get some rtv sealant make sure it's oil resistance and seal around the o rings. Let dry for 1hr or 2 or whatever the direction says and ur good to go.
When u take out ur old o rings gasket if they are hard and cracked that's when u should replace them, any rubber gasket are the same too. If they when they loose they're elastic and get hard then they won't seal as good
Old Aug 13, 2013 | 08:22 AM
I have Rtv red. How much do I put. Just a few drops?
Old Aug 13, 2013 | 03:22 PM
Clean oil off wher the gasket is goin to sit and just place a light coat around the o rings
Old Aug 13, 2013 | 08:40 PM
Jimmy's Avatar
Global Moderator
This might help draw in the right crowd to help you with your questions..
https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
kmeng
Sep 14, 2010 08:02 AM
01blackcivic
Honda Civic (2001 - 2005)
10
Jan 27, 2009 11:34 AM
boogeidream
Sep 30, 2006 08:35 PM
JasonST
Jul 11, 2006 10:08 PM
White Dragon
Jun 18, 2003 08:34 PM
