HELP 91 accord crank pulley broken
Old Aug 12, 2013 | 07:08 PM
NONvtecLSteg's Avatar
Default HELP 91 accord crank pulley broken
ok guys so my buddies 91 accord with an f22.....car died because no alternator cuz the crank pulley was broken so i figured the rubber damper just broke so the inside was spinning etc....got a new pulley and went to fix it and noticed the pulley was in one piece but i could wobble it like a half inch each way but i cant get the bolt loose and i cant use a crank pulley tool because the pully just spins on the crank...anyone have any experience with this? thanks
Old Aug 12, 2013 | 08:51 PM
NZXTInerTia's Avatar
Default Re: HELP 91 accord crank pulley broken
Heat and a big *** impact.
Old Aug 12, 2013 | 11:58 PM
holmesnmanny's Avatar
You can try wedging a pry bar into the flywheel opening and see if it'll hold the crank for you
devilpuppy
Aug 30, 2024 09:15 AM
BlUAc
Jan 28, 2008 03:51 AM
wagonboss
Nov 15, 2002 05:16 AM
johnzm
Jun 17, 2002 07:19 PM
