Help! 1995 civic coupe
Old Aug 12, 2013 | 05:25 PM
EgCouped15b's Avatar
Default Help! 1995 civic coupe
I have a 95 civic coupe that will not have any power when the key is to the on position. I just replaced the alternator and battery. When the key is on there is no power so I need to jump it and when running it will not charge the battery. Any ideas on what could be wrong? The car is not throwing a cel.
Old Aug 12, 2013 | 05:32 PM
B_Swapped93's Avatar
Default Re: Help! 1995 civic coupe
I would suggest you check your main grounds first regardless.
Old Aug 12, 2013 | 05:34 PM
Does anyone have pics of the main grounds? Sorry I'm new to the civics
Old Aug 12, 2013 | 05:35 PM
Former User's Avatar
Do the headlights and hazard lights work?
Old Aug 12, 2013 | 05:36 PM
Yeah they do
Old Aug 12, 2013 | 05:38 PM
Does the starter crank the engine when key is held in ON(III)?
Old Aug 12, 2013 | 05:42 PM
No nothing happens no lights pop on no crank no fuel pump no nothing like the battery isn't connected but it is with brand new terminals
Old Aug 12, 2013 | 05:45 PM
Give more details about this^
Because it suggests that your new battery is dead.
Old Aug 12, 2013 | 05:47 PM
I jump it so the alternator can charge the battery but it does not charge. Have had my battery and alternator tested and still nothing. Can it be a bad ground for the ecu?
Old Aug 12, 2013 | 05:49 PM
When you jump the battery, the engine starts and runs, right?
When you disconnect the jumper cables with the engine running, does the engine stall or keep running?
Old Aug 12, 2013 | 06:02 PM
It still runs like a champ after the jumper cables are off
Old Aug 12, 2013 | 06:06 PM
1) Have the new battery tested. Charge/replace if necessary.
2) When the engine is idling with all accessories off and jumpers disconnected, what voltage do you read across the 2 battery posts?
Old Aug 13, 2013 | 05:53 PM
I have found out my problem. It was a bad ecu ground runs like a champ now! Thanks for everyone's help
BurgerBoulevard
Honda Civic (2001 - 2005)
Jul 26, 2017 06:06 PM
civicstar
Mar 17, 2008 03:37 AM
iperez
Dec 21, 2006 03:10 AM
potential
Aug 6, 2006 07:23 PM
