need help on what engine
Old Aug 11, 2013 | 10:34 AM
stickerkamakazi's Avatar
Default need help on what engine
I've been wanting to swap away my d16y5 with the infamous cvt trans since I bought the car
I originally wanted to go b16a but changed my mind to a b18b1 and doing research I've got my mind all mixed up
my vision is an all motor set up
with around 180 to 200 whp I almost had my heart set on the b18b1 but I can across a thread saying stuff about the bottom end not being balanced and then some more about how non vtec have disadvantages
so im trying to get advice on what really would be a good swap for my criteria
and yes I do plan on building the top and bottom end
Old Aug 11, 2013 | 11:21 AM
nealnanoHX's Avatar
Default Re: need help on what engine
Go with a Ls Vtec setup. What you have heard about the B18B not being balanced is total BS, they are balanced very well from Honda not as much as a Vtec motor yes but still very well balanced. ARP rod bolts are a very good idea to help hold the rods together under higher rmps. Getting to 180-200whp on a non Vtec motor is do able but is harder to get there. It is very easy to do with a Vtec head and good cams.
Old Aug 11, 2013 | 12:06 PM
grumblemarc's Avatar
The Grumpiest
H2B.
Old Aug 11, 2013 | 01:30 PM
motoxxxman's Avatar
I was going to post almost the exact same thing as this, but he beat me to it.
Old Aug 11, 2013 | 11:00 PM
UncleD's Avatar
I would also vote H2B unless you like your car dumped, then I would do a ls/vtec. Do some ARP rod bolts like mentioned above, get some PR3 pistons, Pro1 cams/Pro VT, maybe a valve job, S2 Alpha header and tune!
Old Aug 12, 2013 | 04:57 AM
jimbo slice's Avatar
Running something similar and made 231whp on e85... Blox C's instead of S2
Old Aug 12, 2013 | 11:56 AM
thanks for the info guys
and I do plan on rebuilding the complete motor top to bottom
it wont be my first build but it will be my first Honda build
but on this ls vtec set up does anyone know good places to get the engine and trans
Old Aug 12, 2013 | 11:58 AM
ohh and to just make shure a b18a block with like a b16a head is one example of an ls vtec set up ?
Old Aug 12, 2013 | 07:28 PM
motoxxxman's Avatar
yes, or a b18c head, which will flow a bit better than the b16 head
Old Aug 13, 2013 | 04:18 AM
whitesihatch's Avatar
I support all prior comments. obtaining 200whp out of an ls isn't impossible, but it will be hardly able to dd. Honda has provided us a great technology called vtec, so take advantage of it.
Old Aug 13, 2013 | 06:01 PM
EsotericImage's Avatar
Retired Moderator
If its a street driven car, then who cares about HP #'s , Id be looking for the torque curve!
200WHP is doable, but you better have deep pockets. Id look to a B20 before a B18 as theres no replacement for displacement.
Cripton805
Jan 3, 2013 06:41 AM
1sikhatch
Jun 5, 2009 04:50 AM
mcgee*
Jun 9, 2005 07:30 PM
ntegnifong
May 30, 2005 02:46 PM
Maximus
14
Dec 6, 2001 09:36 PM
