2010 TSX won’t start after accident
Thought this might be the best forum to post in. If not, please let me know where.
I am rebuilding a 2010 TSX 2.4L that was in an accident. I’m wondering if there is a lock-out circuit, switch, etc that would disable the fuel pump from operating after an accident. The drivers airbags did deploy, also a broken motor mount. So if anyone knows what needs to be done to get the fuel pump running again, I would welcome your comments. By the way, have checked all associated fuses.
PS: When I first tried to start the car, it started, but then died after a few seconds. Tried it again, it started but died again. Pumping the gas made no difference. Now it cranks over but doesn’t start. At least tells me the injectors & spark are working. I’ll start digging into the electronics of the fuel pump tomorrow but thought others might have the answer.
Thanks for any help
Thanks for any help
Thought I would let future searchers know what I found in case others have a problem. I had started disassembling the car, including the air cleaner MAS sensor. I had reconnected everything to bring it back to where it started, but I hadn't reconnected the hose from the air cleaner to the throttle body. That was it, the MAS had to sense an airflow. Put hose back on, started on 1st try!
LilMissCrystal81
Nov 19, 2004 11:26 AM
.Noah Fecks
11
Aug 9, 2003 08:06 PM
