Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
engine speed inconsistency
Old Aug 10, 2013 | 03:08 PM
alpiniste's Avatar
Default engine speed inconsistency
So, after I changed the head gasket and cleaned out the egr passages, I am getting a P0420, go figure, right?... So I followed the ECU reset procedure posted here https://honda-tech.com/forums/honda-civic-2001-2005-78/02-honda-civic-p0420-code-3014147/ by It Wasnt Me. During the revving of the engine part I noticed that the rpm would jump around a bit approx. every second. Here is the video of it:
I was noticing the same pulse driving it on the highway right after the rebuild.
Currently the CEL is not on, and I have yet to drive it around town to see if it comes back on.
there is a slight hesitation in any gear with maintenance throttle, and going from decel to accel slightly produces a noticeable driveline shudder. Has anyone experienced this before?
Old Aug 11, 2013 | 04:48 PM
lazlong's Avatar
Default Re: engine speed inconsistency
With an inconsistent idle my first thought is the Idle Air Control Valve (IACV) but, the surging idle in the vid isn't really consistent with an IACV problem. It would jump a lot more and not be as rythmic.
I think with the P0420 after the blown headgasket it's much more likely the catalytic convertor is bad and restricting your exhaust. blown headgasket= engine burning a lot of crap= bad cat
Old Aug 11, 2013 | 08:13 PM
alpiniste's Avatar
idling it purrs like a kitten. only with foot on the gas it does this
Old Aug 11, 2013 | 09:41 PM
lazlong's Avatar
Sorry, sometimes my reading comprehension isn't the best. I saw "maintenance throttle" and thought "idle".
I still think you might have an exhaust restriction (bad cat). It's not uncommon to have the cat go bad (P0420) after the headgasket. Might also be a slight mis-fire, which could be due to any number of things. See if you can get another code out of it.
Here's some good video's about exhaust restrictions and the cat:
Old Aug 14, 2013 | 06:13 PM
alpiniste's Avatar
Thanks a lot for those videos, i will head out to harbor freight tomorrow, i always wanted a reason to buy a thermometer lol
r berq
35
Mar 23, 2015 08:45 PM
skinney6
79
Aug 3, 2012 07:28 AM
Dekorum
Engine Management and Tuning
Apr 3, 2012 07:25 AM
04yfz
Apr 18, 2009 09:11 PM
phill
Sep 9, 2004 08:01 AM
